-   -   1967 Camaro Power Steering Problem (http://www.hotrodders.com/forum/1967-camaro-power-steering-problem-144774.html)
deegainey 09-07-2008 06:37 PM
Hey Guys,
Power steering on my 67 Camaro only seems to work when the fluid is cold. I replaced the pump and lines, but no change. Is there any chance the pressure from the pump is wrong? Or am I looking at a new box?
Any help would be appreciated.
Thanks
Deegainey
C-10 09-07-2008 07:29 PM
Could try and go a little stiffer on the pressure relief valve spring in the pump.
Is it quiet at all times?
deegainey 09-08-2008 06:54 AM
It seems to make a bit of noise as its revved up a bit.
Maybe air left in the system?
