1967 Camaro Rear End Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2011, 04:48 PM
Hey guys,
I am rebuilding a 67 Camaro and am ready to install the engine and tranny. I currently have a 3.08, 10 bolt, non-posi rear end (original on the car), and am going to put either a saginaw 4 speed (1 groove on the input shaft), or a muncie M20 in it as they are what I have in my shop. Is this going to be a dog in first gear? I have a 327 running the whole thing, and consiously chose a cam that will produce some low end torque when I was building the engine (engine will have about 350-380 HP). I am not wanting to drag the car all of the time, but don't want to have a pig off of the line either.
Any thoughts?
Thanks,
Chris
Old 04-08-2011, 04:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Hard to say how much of a dog it will be but if it was me i would have at-least 3.73s or 3.42s under it.JMO What size tire are you running on it ?
Cole
Old 04-08-2011, 06:10 PM
prostreet6t9's Avatar
Differential/Driveline
If it was me 28" tire I would run 373 ratio. 26" tire I would run 342 ratio.
Old 05-02-2011, 04:21 PM
Home for your old rear end
If you decide to off that non posi I would have a home for it in my wife's 67 convertible. The 2.73 is making noise and I would like to step it up a bit for her.
Old 05-11-2011, 12:46 AM
Just be prepared to replace the clutch disc every 25K miles. You'll be slipping it a lot from a dead stop.
Use a Sag with 2 rings (3.11 low). Works much better with 3.08's.
1967 Camaro hotrodsixtyseven Introduce Yourself 5 03-19-2008 07:29 AM
1967 Camaro Doug Graham Introduce Yourself 1 04-11-2007 07:00 AM
67 camaro rear end question shclayto Transmission - Rearend 6 10-11-2005 09:24 PM
1967 Camaro d_67_camaro Interior 2 02-01-2003 02:37 PM
rear end for 1967 camaro old67camaro Transmission - Rearend 1 11-19-2002 02:34 AM
