1967 Camaro tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2010, 03:24 PM
oldtimercarnut's Avatar
1967 Camaro tires
Hi guys
I have a chance to buy some tires and rims for my 1967 Camaro but I need your help. The size of the tires are, back 275-60-15 on 8" rims with 4 1/2 back space. Front is 235-70-15 with 4 1/2 back space. Do you think I will have trouble with the tires fitting on the front? Thanks
Old 10-20-2010, 03:27 PM
1967 Camaro tires
Hi guys
I have a chance to buy some tires and rims for my 1967 Camaro but I need your help. The size of the tires are, back 275-60-15 on 8" rims with 4 1/2 back space. Front is 235-70-15 on 6" rims with 4 1/2 back space. Do you think I will have trouble with the tires fitting on the front? Thanks
Old 10-20-2010, 03:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It all depends on how low or how you have your front end sitting.
Cole
Old 10-20-2010, 03:29 PM
eloc431962's Avatar
Wiki Edits: 37
Double post.
Cole
Old 10-20-2010, 03:54 PM
I have done no modifications to the front end. It is just stock.
Old 10-21-2010, 12:12 AM
JeffB's Avatar
You might want to check the Discount Tire website,you can get height and width measurements there,in your case I would run a 205/70/15 on the front.
Old 10-21-2010, 04:18 AM
I decided last night to pass on the tires and rims I have a chance to buy. I have a set of Torq-Thrust D rims that are 15X7 and 15X6 that I am going to use. I am placing 275-60-15 on the back. And like you said, and I agree 205X70-15 on front. Thanks for the reply.
Old 10-21-2010, 04:47 AM
Old 10-21-2010, 02:38 PM
eloc431962's Avatar
Wiki Edits: 37
On my 67 camaro the bigest tire wheel combo i could go with was,
P205/65r/15 on the front with a 15x6 with a 3 1/2 backspacing. Any bigger and they rubbed my fenders when i turned the wheels but that might all change when i do my suspension. My springs are pretty soft there are pics in my gallery and one for my avatar you can see how it sits.
And mine has stock rear never been cut on and i went with a 15x8 4 1/2 back space with 255/60/15 tires on there.any bigger and they rub.
Cole
max valve lift for 1967 Chevy 327 camaro double hump heads?? kuhn-77 Engine 1 08-18-2006 06:12 PM
1967 firebird - camaro conversion Johnny Bravo Body - Exterior 3 10-10-2003 12:30 PM
1967 Camaro Wiring? ToYoungToCare Electrical 5 08-24-2003 05:28 AM
1967 Camaro restoration Help ToYoungToCare General Rodding Tech 5 08-23-2003 05:28 PM
1967 Chevy Camaro Hellp ToYoungToCare Body - Exterior 13 08-18-2003 05:38 PM
