It's hard to tell you where to start but there's an adjustment screw and lock nut on top of the gearbox. Loosening the jam nut and turning the screw in (CW I think) will push the sector shaft further into the worm gear and tighten up the slop if that's the problem. If it's a manual, most of those boxes are worn out. I think a Blazer or 4x4 PU power box will bolt in with very little hassle and that's what I would do. factory brackets and PS pump and a crank pulley from the same app will finish the job. Factory PS hoses for a 72 4x4 should also work. Also check the tie rod ends and the drag link ends that go from the pittman arm to the d/s spindle. Another thing that many don't check is wheel bearings. Those double nut 4x4 adjusters will come loose. Another thing is check the pre load sleeve on the upper ball joint at the spindle. Wear and lack of pre-load will make it road crazy. The upper and lower ball joints can be replaced without serious special tools. Some of this stuff should have been checked by the alignment shop when that was done, so it's hard to tell you what to check.
speedbump, thanks!!
In reading what you wrote I am leaning towards the balljoints.
I will have to get a shop to do the ball joint job and hope they know what they are doing with regards to "preload" If I knew more about how to do it I would. Thanks |
| 383 chev motor in 1967 van what overdrive trans? | twinpilot001 | Transmission - Rearend | 3 | 12-22-2010 11:16 AM |
| 292 Chev Straight Six Go Fast Bits? | red rs ss 68 | Engine | 7 | 07-01-2008 06:50 AM |
| 1967 Chev Van | CHRISJEN | Engine | 3 | 07-15-2007 09:07 PM |
| hey anyone know how hard to put straight axel in 61 falcon | Evil61 | Suspension - Brakes - Steering | 1 | 11-13-2005 12:10 AM |
| 1938 chev - straight axle front end | WILLARD(SONNY)STOTLER | Suspension - Brakes - Steering | 4 | 12-30-2001 03:26 PM |
