1967 chevrolet 4x4 k-10 pitman arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2009, 10:37 AM
How's it going, I'm restoring a 1967 CHEVY K-10 4x4, I need a PITMAN ARM,I've searched almost everywhere on the web,If anyone knows where I can FIND one ,or Has one,or if some other application will work for me,PLEASE E-MAIL ME THANKS A LOT? :
Old 06-16-2009, 10:41 AM
prostreet6t9's Avatar
Differential/Driveline
Try here...... http://www.fillingstation.com/
Old 06-17-2009, 06:16 PM
THANKYOU,PROSTREET6t9
I went to that WEBSITE, CALLED THEM, THEY DON'T HAVE THE PITMAN ARM,AND SAID THEY ARE HARD TO COME BY THEY GAVE ME SOME PHONE #s TO 2 WRECKING YARDS THAT SPECIALIZE IN OLD CHEVROLET PART'S,1800-886-7277&1800-955-4999 THANK'S FOR THE IMFORMATION AGAIN!
Old 06-17-2009, 07:15 PM
i've had the same problem on 2 of my own 67 4x4. used a jeep pitman arm with a hole in it then made a small drag link. worked perfect. i am looking for another 67 k20 to restore
Old 06-17-2009, 11:24 PM
I thought for sure they would have it! They're in my neck of the woods and always had what I needed.
Have you tried http://www.lmctruck.com/icatalog/cb/full.aspx?Page=139
Old 06-18-2009, 07:32 AM
If this guy don't have them, I don't know if they exist! http://www.vintagechevytrucks.com/index2.html
And don't just look at the web site, give him a call. He is a way more "parts store" than "web site" kinda guy. He has a beautifully organized indoor stored supply of parts in a large warehouse. He is bound to have it!
Old 06-19-2009, 06:01 PM
fast68's Avatar
likes chevy trucks & boobies
should be manual steering type pitman arm and '64-87 same technically
lemme do some research on this because i have forgotten details but i know that 67 68 years power steering was still the old style with the lines running to a ram cylinder on the centerlink bar like the corvettes had
is your truck power or manual steering?
67 should be manual type arm either way however
output shaft diameter could vary however hmm
theres one on this page: http://www.automotix.net/partshotlin...-requests.html
Used 1967 Chevrolet / Chevy K10 Pickup pitman arm
Pickup, V-8, Gas/Carburetor, 3-Speed-Std, 4x4 pitman arm battle creek, Michigan 49015
Old 06-19-2009, 06:22 PM
Originally Posted by fast68
'64-87 same
take one from a later truck
LMC is listing different parts numbers,.. 67 to 68 part#34-2220, 69 to 72 part#34-2222 for the 2WD. For the 4WD they only show 70 to 72,nothing earlier. I'm not sure what the difference is.
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
1982 Trans Am W/ BW T 10 - using torque arm Trans Am Tony Transmission - Rearend 1 04-23-2007 06:39 PM
t 10 ford and t 10 chevrolet retired 56 Transmission - Rearend 0 03-24-2007 05:14 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
Chevrolet 8.5" 10 Bolt bigjoedo Transmission - Rearend 3 06-06-2002 05:00 PM
