1967 Cougar - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2011, 09:26 PM
Last journal entry: Gas cap next
1967 Cougar
I'm not sure if this is the correct category, but I just bought a headlight switch and it appears that the headlight door (hidden) vacuum distribution is now part of the switch instead of the valve on the inner fender. Does anyone know if this is correct ? There wasn't any instructions included with the switch.
Any help would be greatly appreciated.
Old 09-30-2011, 05:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds to me like you have a switch for a 1968 cougar instead of a 67. JMO
1967 is the only year that has (Headlight Vacuum Solenoid) then in 68 went to what you are describing with the one you have. 67 cougar and T-bird have the same set-up the rest are different. In the pics below the one on the left is for the 67 and the one on the right is for the 68 cougar.
Cole
ID:	58710   Click image for larger version
Old 09-30-2011, 08:21 PM
1967 Cougar
Will the '68 switch work on the '67 ? The auto supply store lists it for the '67 also.
The only thing it does is change the direction of the vacuum.
1967 Mercury Cougar 1967 cougar Introduce Yourself 2 02-01-2011 03:19 PM
68 Cougar Matt44 Hotrodders' Lounge 8 09-22-2009 07:08 AM
1967 Cougar decal locations LS-57 Engine 6 01-13-2009 10:07 AM
1967 cougar decode help pi71 Hotrodding Basics 2 07-09-2007 12:15 PM
1967 Cougar Curtis Hermann Introduce Yourself 3 07-23-2005 12:01 AM
