Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1967 El Camino rear brake line
Old 11-19-2012, 04:50 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Originally Posted by Chucky5150 View Post
It was 1/4 inch line from the metering block back to the rear axle.
Use the 1/4 line then....If you use 3/16 you would need an adapter at the rear fitting.
