-   -   1967 GM "A" Body sheet metal alternatives (http://www.hotrodders.com/forum/1967-gm-body-sheet-metal-alternatives-227485.html)
jim owens 12-23-2012 06:25 AM
I need Rear Quarter Panels & Trunk drop filler extentions for my 67 Skylark. What GM "A" Body would best closely resemble the body style/ curves / & lines. They do make these parts for 67 chevelle/cutlass/lemans & temptest etc... but as of right now NONE for 67 skylark. I will buy the part that is as close as I can get, and then cut & weld, but I am not sure what car I should be looking at. What would you guys/gals suggest as a good alternative / substitute. Has anyone out there done this on their 67 skylark. Thanks JIM
69 widetrack 12-23-2012 06:33 AM
I have not done a 67 skylark but the trunk drops are similar to all the cars that you mentioned. The most similar, if memory serves me correctly is the Cutlass. I'm sure with a little trimming (you usually need to trim any part like this regardless, even if it's car specific), it can be made to fit and fit well. I have done several 66, 67 Chevelles with this same problem before aftermarket parts where available and made the piece. If your originals are good enough to use as a pattern, that may be another option.
Hope this helps.
Ray
jim owens 12-23-2012 09:06 AM
Thanks Ray, The last couple of hours I have been searching thru the internet to see who has the "closest" match". ShermanParts is the most likely candidate. Now I just have to choose from the pictures, which is the best one. Thanks JIM
gearheadslife 12-23-2012 09:30 AM
have you hit up, then and now, in weymouth,ma.
they might know where the parts you need are..
tech69 12-23-2012 10:32 AM
you can fab those up really easy with a brake and bead roller, or even hammer formed 2x4's, but then again if you had those tools you probably wouldn't be asking.
joe_padavano 12-23-2012 12:56 PM
Nothing.
Each division used completely different exterior sheet metal. Nothing else interchanges. 66/67 Skylark is probably the only interchange.
jim owens 12-24-2012 10:26 AM
I ve seen some cheap shhh*t from jc whitney, I m not even going to waste my money & time, - I ll call Then & Now after the new year and If they can't
find it, I guess I'll try my luck fabricating my own, Thanks to ALL for your ideas & info ----JIM
69 widetrack 12-24-2012 11:50 AM
I started feeling sorry for you...with your rear quarters and all...I understand...I had to build rear quarters for an AMX years ago and it can be a bear...so I did a bit of searching....try these guys.
Buick Skylark Lower Quarter Panel 2 Door Left 1967
I hope it helps...it may not be exactly what you want but it's probably better than what you have.
Ray
jim owens 12-24-2012 12:04 PM
Again thanks Ray --- thats the NAAI Inc steel qtr panel # 10530G from jc whitney --I ve heard they are junk --thanks JIM
69 widetrack 12-24-2012 12:15 PM
Okay Jim, I know it's a nasty situation...The AMX I did all those years ago I couldn't even get anything close to looking like AMX quarters. I didn't realize that those where the JC Whitney kind...thought if nothing else you might be able to piece a quarter together.
51 styline 12-24-2012 02:51 PM
I punched in 1967 Buick Skylark 1/4 Panel and several came up on the internet. They were used units and i didn,t find any full 1/4s. There were partial replacement panels available new. Hope this helps.
