1967 GMC half ton, which differential is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2013, 05:30 PM
1967 GMC half ton pick up rear end number is 3886888! Is this a posi
Old 03-02-2013, 05:35 PM
Ment rear-end
Old 03-02-2013, 09:00 PM
big gear head's Avatar
High Performance Rear Ends
Pictures please.
Old 03-02-2013, 09:10 PM
rear end i.d.
Photos would help greatly. does it have a bolt on rear cover? To find out if its a posi, jack up rear of truck and safely support it. Then with the transmission in neutral, grab one of the tires and rotate in either direction if both tires turn in the same direction it may be a posi unit. You could also take off the rear cover and check it out too.
Old 03-02-2013, 11:56 PM
Thanks guys! Will get pic tomorrow!
1956 GMC half ton BLDBOMER Interior 1 03-29-2012 08:39 PM
Is it possible to get a disc brake conversion kit for a 1967 GMC 3/4 ton truck? Burrell Suspension - Brakes - Steering 1 08-07-2011 11:39 AM
3/4 ton rear end in half ton truck zoomo Transmission - Rearend 3 10-25-2010 06:30 PM
need help changing out sterring collumn on a 1979 gmc high sierra half ton 4x4 81scottsdale400 Suspension - Brakes - Steering 4 10-10-2010 11:14 PM
1967 GMC Heavy Half Cliff.E Introduce Yourself 2 05-15-2009 07:54 AM
