1967 GTO suspensiom issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2012, 12:27 PM
I recently bought a 1967 GTO basket case. The body is in excellent shape as is the frame. I need help with the details on the mountingof the rear coil springs.
Old 08-30-2012, 03:17 PM
LATECH's Avatar
Rear springs should be easy.The top of the spring has a rubber insulator that slides over the top coil , to help with noise and spring pocket wear.
The bottoms should just rest in the little saddles on the rear end.
They may also bolt down with a little retainer plate.
When you put on the shocks, they limit the suspension travel so the springs cant fall out.Hope this helps.
Fact is stranger than Fiction
Need a horn relay for a 1967 GTO Overdriv Electrical 4 05-02-2011 06:04 AM
1967 Gto cliftondavis9 Introduce Yourself 1 11-07-2008 01:57 PM
1967 Pontiac GTO brakes slege Suspension - Brakes - Steering 7 02-23-2006 03:17 PM
1967 gto suspension 1974 gto Suspension - Brakes - Steering 1 04-12-2004 01:27 AM
Tubbing a 1967 GTO jimmy1967gto Transmission - Rearend 1 02-09-2003 03:07 PM
