1967 Mustang Big Block Motor Mounts
I am restoring a 1967 Mustang "S" code with a 390 engine. The motor mount bracket that bolts to the block has two knurled studs that connect the upper Block) bracket to the rest of the mount. The studs are 7/16-14 by 1" knurled press-in studs. One of them twisted off and needs to be replaced.
I have driven the parts houses crazy looking for replacement studs but no one has them. Everyone I contacted sez buy a new set of upper brackets but $130 or so seems a lot. I have thought of trying a wheel stud that would fit or just welding in a #8 bolt. Anyone know where I could get the studs, a single replacement bracket or any suggestions on fixing my old one? |
This place should be able to set you up with the part that you're wanting. He's not cheap but he's a very honest person.
http://www.cougarpartscatalog.com/ edit; I checked his site out and it looks he is higher than the prices that you got. Last edited by Kampr; 02-19-2011 at 04:43 PM. |
Those are called "ground studs".
Here's a mfg of them, they don't list a 7/16" version on the website but I am sure they can make anything you need since they are custom. http://www.pkprecision.com/StandardNewValidated.htm I'm assuming this is for originality for your restoration and want an exact match, if originality is not important I would just use a bolt tack welded to the plate...a lot cheaper.
Outlawed tunes from outlawed pipes |
Thanks Guys,
I didn't find exactly what I was looking for but these are some good sources for the future. I welded in a #8 bolt and it works fine. Just wanted to stay with original type parts if possible but after a little dressing up you have to look real close to tell the difference. Thanks again. |
| big block motor mounts | bigdog7373 | Engine | 1 | 05-11-2010 08:58 PM |
| 69 mustang 5.0l motor mounts | pyr0 | Engine | 2 | 07-23-2009 11:36 PM |
| can i use small block motor mounts for a big block? | 402 Camaro | Engine | 5 | 01-25-2008 07:33 AM |
| '65 Mustang Motor Mounts | 65Stanger | Engine | 3 | 06-18-2006 12:06 AM |
| mustang motor mounts??? | shagginwagonvic | Engine | 3 | 01-19-2004 08:30 AM |
