1967 pontiac 455 overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2003, 12:12 PM
brisk's Avatar
first off I would like to say hello to eveyone as this is my first time on the hotrodders bulletin board. I have a 1967 pontiac firebird with a rebuilt 1974 pontiac 455 that I bought last year. I have tried so many things to stop it from overheating. I have a friend who is a retired mechanic who is helping me. We have replaced the thermostat, put three electric fans on it,checked the water pump, put in water wetter and a few other things. We cannot get this car to stop overheating! We thought it might be boared out to much, but found out it is only 30 over. The car runs for about 25 minutes, gets up to 180-190 and cannot hold. It has a serpantine belt system with a standard flow pump that we just chacked yesterday. We are going to open it up this weekend to see if something is blocked inside. We found out through the previous owner that it has a homemade cam. If anyone can suggest anything it would be much appricieated. THANKYOU>
Old 08-14-2003, 12:17 PM
bullheimer's Avatar
NEVER use credit cards!
no, i really cant give you any ideas. some of the big block camaro guys probably can tho. i have a 66 tempest as you can see, so i just want to say welcome to another poncho man and i hope you fix your overheating problem. do you have headers? ceramic coated? that could help some. you shouldnt have to cut any holes in your inner fenders.
Old 08-14-2003, 12:23 PM
EBlack36's Avatar
Rebuilt Excitment
Make shure that your water pump is turning in the correct direction with the serpantine belt system. some of these need a reverse flow water pump.
Old 08-14-2003, 12:39 PM
CJ2AWILLY's Avatar
SBC and foot in the carb
Brisk, welcome. I had the same problem with a '65 GTO/444. In additiona to what EBlack36 recommended, you might want to check behind the water pump to see if the tubes that go between the water pump and the timing cover are in good condition. If they are bad or not there at all, the water will not circulate through the block.
Old 08-14-2003, 08:33 PM
400C53F100's Avatar
Feel the radiator core. It should be uniformly hot across the top or inlet side. The outlet side will be slightly cooler with no cold spots anywhere in the core.
You could also use a thermometer inserted into the fins to do this.
If the outlet side is much cooler than the inlet then there is not much circulation.
Old 08-15-2003, 12:42 AM
Make sure the metal plate is behind the water pump.
Old 08-15-2003, 02:01 AM
Pontiac Knowledge Base Editor
Also if anyone has ever put stop leak in the radiator, which is a big no no in a poncho, the water jackets in the heads are only drilled 1/8 to 1/4 inch and the plug up quick with stop leak.
Old 08-15-2003, 02:11 PM
6567GTO's Avatar
Tire Fryer
Lot's of good advice given so far.
Also check to see if the water pump has a stamped steel impeller instead of a cast one. If it's a stamped steel one, get rid of it -they're junk. I've even heard of them being stamped where the fins are bent in the wrong direction causing it to flow terribly. Get a good factory steel flex fan for it too. If it has an aftermarket fan it may not be hvy duty enough. I had one years ago that would flatten out when revved and it would block the flow of air through the radiator. What are the head casting numbers? What compression is it? What kind of gas are you using?
Old 08-19-2003, 08:50 AM
6567GTO's Avatar
Tire Fryer
How did you make out this weekend Brisk? What did you find?
Just curious.
Old 08-19-2003, 01:17 PM
brisk's Avatar
Thanks for asking but we did not do it last weekend but will open up the engine this weekend. After doing some research, and talking to whoever we could, we think it is in the heads, so were going to inspect them, we just don,t think we are getting any coolant to the engine or it isn't doing any good. Will let you know.
Old 03-04-2007, 02:18 PM
overheating
Before you spend money on water pumps ,radiators etc do a coolant check to see if you have leaking head gasket.
Old 04-03-2008, 11:17 PM
overheating
in the end , what did you finally do to correct your problem. i have the same problem and i am looking for the answer.
