-   -   1967 Pontiac GTO brakes (http://www.hotrodders.com/forum/1967-pontiac-gto-brakes-81824.html)
slege 02-16-2006 06:43 AM
Does anyone have an illustration on how the rear brakes are assembled? I had none of the adjuster hardware on my car when I got it.
Deuce 02-17-2006 01:34 PM
As a moderator here, I would like to WELCOME YOU here.. :welcome: :welcome:
http://img.photobucket.com/albums/v1...ereference.jpg
This is a Ford backing plate with the self adjusters........not a Pontiac but they are basically the same.........and should get you started in the right direction.
poncho62 02-17-2006 01:59 PM
The Pontiac wont have the cable for the adjuster.........it's a lever type.
slege 02-20-2006 03:22 PM
another question
Poncho,
On on the hardware I bought to put in my car, there is a piece of wire (similar to #9 wire) that is bent. I have seen them used before but I don't remember where it goes, can you help. I think I can get the rest with that information. Thanks
xntrik 02-21-2006 11:58 AM
Good procedure, passed on from old-timers..... only disassemble one side at a time.
slege 02-21-2006 03:18 PM
not a retard
Given the opportunity to view one side done correctly would have made this project too easy. One of the "old timers" removed the adjusters just like the ones in the old days. Thanks for your insight.
yesgo 02-23-2006 07:53 AM
2 Attachment(s)
hope these help. they are GM 9.5" rear 67-81
slege 02-23-2006 03:17 PM
Thank you. That was exactly what I needed. ;)
