1967 Pontiac GTO brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2006, 06:43 AM
Does anyone have an illustration on how the rear brakes are assembled? I had none of the adjuster hardware on my car when I got it.
Old 02-17-2006, 01:34 PM
As a moderator here, I would like to WELCOME YOU here..
This is a Ford backing plate with the self adjusters........not a Pontiac but they are basically the same.........and should get you started in the right direction.
Old 02-17-2006, 01:59 PM
poncho62's Avatar
Wiki Edits: 5
The Pontiac wont have the cable for the adjuster.........it's a lever type.
Old 02-20-2006, 03:22 PM
another question
Poncho,
On on the hardware I bought to put in my car, there is a piece of wire (similar to #9 wire) that is bent. I have seen them used before but I don't remember where it goes, can you help. I think I can get the rest with that information. Thanks
Old 02-21-2006, 11:58 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Good procedure, passed on from old-timers..... only disassemble one side at a time.
Old 02-21-2006, 03:18 PM
not a retard
Given the opportunity to view one side done correctly would have made this project too easy. One of the "old timers" removed the adjusters just like the ones in the old days. Thanks for your insight.
Old 02-23-2006, 07:53 AM
abstruse dutch uncle
hope these help. they are GM 9.5" rear 67-81
ID:	10260   Click image for larger version
Old 02-23-2006, 03:17 PM
Thank you. That was exactly what I needed.
I'm Bored...How About A 1967 Pontiac GTO Project ??? izzymiddleton Hotrodders' Lounge 9 03-07-2009 10:26 PM
1967 pontiac 455 overheating brisk Engine 11 04-03-2008 10:17 PM
Pontiac GTO commercial street racing fourbyfourblazer Hotrodders' Lounge 28 08-11-2005 04:15 AM
1953 Pontiac brakes hyperkick Suspension - Brakes - Steering 3 10-22-2004 08:00 PM
will 68/69 GTO disc brakes fit 67 camaro 67454 Suspension - Brakes - Steering 3 12-18-2003 08:07 PM
