1967 Pontiac Super Turbine 300 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 01:56 PM
Does anyone know of a good reputable remanufactured transmission source that carries a Super Turbine 300 transmission for a 1967 Pontiac Lemans with a 326 engine?
Old 09-01-2012, 02:12 PM
joshp83's Avatar
owner of Prices Garage
im located in wva i take it your from idaho contact jasper threw a local dealer there offering vintage rebuilds
Old 09-01-2012, 03:57 PM
LATECH's Avatar
Last journal entry: New Gas Tank
I quit using jasper ANYTHING some years back when the quality crapped out and there stuff was ragged.
I wouldnt put a t 300 in anything except the dumpster. The car will run way better and get better mileage with a t350 hydromatic.You can get that built right in your home town. Honest Injun... run a T 350.
I have a T 350 in my 64 , and I have owned powerglides and other two speeds and they all lack 2 things...performance and mileage.
I had NO ISSUES when putting in the T 350 in my 64 LeMans. The cross member worked as is, and so did the driveshaft. I didnt have to cut the shaft or anything
Fact is stranger than Fiction
Old 09-01-2012, 06:04 PM
SSedan64's Avatar
I vote for a TH200-4R 4-speed O/D Trans. It'll also swap in easily.
Old 09-01-2012, 06:29 PM
LATECH's Avatar
X2 also a great choice.
Super turbine 300 replacement Rhodesta Transmission - Rearend 1 03-23-2010 05:53 AM
Super Turbine 300 BIGEC Transmission - Rearend 1 02-13-2009 06:51 AM
Super Turbine 300 having Hard Downshifts after Rebuild Larry Davis Transmission - Rearend 6 07-01-2008 06:22 AM
super turbine 300 buickboy Transmission - Rearend 2 04-14-2008 07:56 AM
Super Turbine 300 paul poirier Transmission - Rearend 3 12-10-2004 08:09 AM
