1967 Rally Sport Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 12:04 AM
I have a 1967 RS Camaro Coupe with a 396 which is almost fully complete. The interior needs some work and I'm trying to decide if I want to go back to the all original interior or try something a little different. What I am wanting to do is put the leather interior of a newer Camaro in so I can have a comfortable and unique modern interior in the classic car. If anyone has any ideas as far as how to go about this or if this idea is even feasable please let me know.
Old 09-24-2006, 07:43 AM
Wiki Edits: 31
it really dependson what you want the car to be worth. if you put the newer interior in the car so it's comfterble, in many cases the value will drop, but you could make it look good. If you wan't better than original, but not as good as the newer, and it shouldn't hurt the value. late Gen 2 Camero seats ( '77-81 ) look great in gen 1 Camero's.
Old 09-24-2006, 12:31 PM
New question, i'm not sure if i like the 2-speed power glide tranny that i have in the car now. What other options should i look at that would work best with the 396?
Old 09-24-2006, 01:01 PM
GothRod87
th350 or th400..both are easily atainable....me personally i ran a built th400 in my old camaro and it was ******
GOTHROD
Old 09-24-2006, 01:18 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
TH350 can be built to handle a bit of power and is lighter and smaller than a TH400.
Old 09-24-2006, 01:32 PM
GothRod87
good point..the reason i used the th400 is cause mine had a 396 in it when i bought it and i switched over to a 454 nitrous fed mouse..I wanted a tranny that would hold up so got a th400 and had it rebuilt with a shiftkit and extreme duty internals..depending on what you want to do with it the th350 is a good choice aswell as easy to find
GOTHROD
Old 09-24-2006, 03:05 PM
So if i go with the TH350, then what gears would I want to go with? I don't care about the gas mileage if I did I wouldn't have gotten a muscle car as my 2nd vehicle. The gears that are in there now are lacking, im not excactly sure what they are but they are difinately geared towards the highway. I have a 10 bolt rear end and I have been thinking about going with a 3.73 gear ratio?
Old 09-24-2006, 04:22 PM
Wiki Edits: 31
3.73 would be great. they got good highway manors and are low enough to come off the line quickly
Old 09-25-2006, 12:59 AM
i have been told that i should go with some 4.10 gears, but i dunno if i quite need all of that. how much difference would there be between the two?
Old 09-25-2006, 01:40 PM
Biggarmike's Avatar
Chief Procrastinator
If you have a real 67 RS, it didn't come with a 396, so whatever you do with the interior makes little difference. The 67 deluxe interior is pretty nice as is, but if you want fancier use the deluxe as a pattern and have it done in leather. On the cheap, use 2nd gen Camaro Seats and replace the door trim, kickpanels, headliner, console, etc.
Whatever you do, don't paint it red! and don't add SS stripes and spoiler!
Old 09-25-2006, 05:19 PM
Wiki Edits: 31
you don't need 4:10's, would suffer in drivability with them. 3.73's as I said have better street manors. dosn't seem like much diffrence but there is
67 camaro rally stripes 67goat Body - Exterior 2 06-22-2005 06:22 PM
Crippled 1967 Camaro RS darom Engine 11 10-13-2003 04:45 PM
1967 Camaro restoration Help ToYoungToCare General Rodding Tech 5 08-23-2003 06:28 PM
67 Camaro Rally Sport Jim Vines General Rodding Tech 4 02-19-2003 07:39 PM
1968 camaro rally sport 327 1968rallysportcamaro Engine 5 01-02-2003 09:32 PM
