1967 Starting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2011, 10:29 AM
Hey guys - I am the proud new owner of a '67 Camaro. I recently had the starter and distributor replaced due to some careless work by a previous owner... no big deal... the problem I am having is that now when the new starter turns over there is a hesitation... then as I drive the car throughout the day the hesitation from the starter gets worse and then it basically gets to a point where it does not want to start.
Any help that can be offered would really be appreciated!!
Thx, Kent
Old 08-14-2011, 10:35 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thx, Kent
Explain hesitation. If it's doing what I think, the timing needs adjusted.
Old 08-14-2011, 10:50 AM
Starting Issue
Thanks a lot for the reply. When I turn the key, there is a pause and then it starter starts to engage but it feels like it is not going to crank over until the last moment when it finally cranks fast enough to start the motor... It is a very similiar starting sound/feel as if the battery was firing... Accept I have a new battery.
Old 08-14-2011, 11:03 AM
Wow is my spelling messed up... I was trying to write that the sound/feel of this problem is similiar to starting a car with a dieing battery
Old 08-14-2011, 11:12 AM
EOD Guy's Avatar
Did you ck all the connections? the delay before the starter engages might be an indication of a loose connection, fired wire, the Solenoid going bad on the starter or the starter is improperly shimmed.
Old 08-14-2011, 12:23 PM
Thank-you very much - I will check
1967 camaro starting issues kimmilil Engine 3 06-20-2011 01:38 AM
i am having starting issues with my 350 83chevytruck Engine 3 04-12-2011 09:27 PM
hot starting issues on C10 redtide151 Electrical 3 07-21-2009 08:25 AM
283 starting issues 283jeep Engine 17 04-03-2007 12:48 PM
1967 Camaro Starting Failure colincamaro Engine 2 01-20-2007 04:29 PM
