Thread Tools Search this Thread share on Facebook
  #1
Old 09-02-2011, 10:06 PM
tech69 tech69 is offline
1967 VW bug window regulator
We're trying to make do with used regulators but both have a slight bend on the regulator where it bolts to the bottom of the door. It has all new rubber window channels and they're greased up, fully seated, and are open enough to where it should roll up good but when it gets to the top it's binding somewhere. I believe it's cause the bend at the bottom of the brace that runs up/down and bolts to the bottom of the door. I think it leaves the glass at a cocked angle. Does anyone know of they're supposed to be bent? I feel like taking the door panel back and just taking my slide hammer and yanking it out a bit cause to take it off means to take everything out, if you know the order to bolt those doors up...they suck!
Any help appreciated.
Register now (free) or login to remove ads
Old 09-02-2011, 11:05 PM
benchracer1 benchracer1 is offline
If you go thesamba.com you will in all likelihood find good info on this.....Steve
Old 09-04-2011, 09:34 PM
thanks, I'll try that.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1967 VW bug window regulator"
ThreadThread StarterForumRepliesLast Post
35 window regulatordrchipHotrodding Basics103-01-2011 07:45 AM
66 Merc window regulator?Localboy808Body - Exterior402-24-2011 11:14 PM
Window regulator26 StudeHotrodding Basics1202-09-2011 08:54 AM
el camino window regulator same as monte?fast68Body - Exterior111-22-2009 07:05 AM
1937 Ford Window regulatorwallyInterior311-10-2002 07:54 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
