1968 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2010, 03:45 PM
1968 10 bolt
Did 68 el camino 10 bolts come with posi? as an option maybe?
I have the rear end out of the car, is there an easy way to tell if it is a posi rear end? i took the pan off and took a pic of the internals and will post them soon.
I have a eaton posi unit in my 12 bolt and the internals look very different then what is in my 10 bolt.
Old 03-21-2010, 04:52 PM
ericnova72's Avatar
More for Less Racer
Yes, a '68 10-bolt could have been ordered with a posi. I pulled one posi unit from a junked '69 Elky years ago. It isn't the strongest as far a posi units go, but servicable at less than 375 hp and no slicks.
Post a pic, but it will be obvious if it is posi, it will have the preload plates and 4 springs between the axle gears, around the center pin.
Old 03-21-2010, 06:55 PM
http://img16.imageshack.us/img16/9630/850a0962.jpg
http://img260.imageshack.us/img260/150/850a0961.jpg
http://img11.imageshack.us/img11/8080/850a0960.jpg
http://img228.imageshack.us/img228/6141/850a0959.jpg
http://img191.imageshack.us/img191/3094/850a0958.jpg
Old 03-21-2010, 07:16 PM
ericnova72's Avatar
More for Less Racer
Thats just a run of the mill standard open differential, nothing special about it.
Old 03-21-2010, 07:18 PM
Ok, thanks for the intel.
I am am probably just going to give it away if anyone wants it, i had it up for sale for a while and didn't really get any bites on it. I am pretty sure it has 3.06 gears in it.
10 bolt or 12 bolt???? tinman386 Transmission - Rearend 14 07-31-2007 02:03 AM
Swaping 10 bolt rear ends, what will fit? fansick Transmission - Rearend 5 07-13-2007 02:41 PM
10 bolt vs 12 bolt jeff88s10 Transmission - Rearend 2 06-21-2006 03:41 PM
10 bolt or 12 bolt neil madsen Transmission - Rearend 2 02-25-2003 06:55 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
