1968 - 1969 YW block. I can't find a DISTRIBUTOR that fits the oil pump shaff - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2008, 09:49 PM
I have a 1967 Firebird with a 1968 - 1969 YW block. I can't find a DISTRIBUTOR that fits the oil pump shaff.
I have bought a accel distributor, a stock one with points and now order one from summit and stell dosen't fit.
It seems the oil pump shaff is to big, I have put a 1/2" socket on the oil pump shaff it's a snug fit, i put the 1/2" socket side by side with the distributor and the socket & oil pump shaff looks a little bigger than the distributor.
Could it be the oil pump shaff be to big?? or spread apart??
I'm lost please help
Bryan
Old 06-12-2008, 11:36 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Sounds like you're just not getting it lined up with the shaft slot.
Old 06-13-2008, 12:38 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Byan, Is the pump mounted in the engine and the shaft not? If so, grind the tangs off of the side of the shaft, but be very careful dropping it down to the pump. If it misses, it can go down in the pan. The shaft was made to go in from the bottom, with the oil pump installed after, to keep it in place.
ID:	30581   Click image for larger version
ID:	30582   Click image for larger version
Old 06-13-2008, 03:57 PM
boatbob2
oil pump shaft.....
HI,above is good info,however use a set of mechanical fingers to hold the shaft,so you dont drop it in the pan..
Old 06-16-2008, 10:04 PM
No Luck
The oil pump and pump extension is installed in engine.
I toke the gear off of the distributor and installed it and it fits into the oil pump shaft and down on the block. NICE
I put the distributor gear down on top of the oil pump shaft and the shaft diameter is to big!
Thinking about buy some long needle nose plier's and squeezing the shaft together so it mite fit? probably not so smart move
OR Replacing the oil pump and pump extension? probably the smart move
But more work and money
*** This is my first time asking for help online, and it's pretty cool
Thanks for helpping
Old 06-16-2008, 10:15 PM
I was thinking
Do yal think I could grind the inside of the distributor gear to fit over the oil pump shaft extension?
The distributor gear shaft is pretty thick?
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
