1968-1970 12 Bolt Rear Axles Same Length?
Looking To Replace 2,76 Open 12 Bolt Rear Axle In 1970 Cutlass With A 12 Bolt 3.08 Posi From 1968 442 ...........will They Be Same Lenght ?
The O axle was used in the Cutlass from '68 to '70, so both of these rear ends should be the O axle, and they will be the same width. The O axle has 12 bolts in the cover and 10 in the ring gear. The axles don't have c clips, they bolt in like the 9 inch Ford.
If they are both A-body axles, yes the Chevy 12-bolt is a bolt-in. The only thing to watch out for is the driveshaft length. The Type O axle in there now has the pinion flange in a different location than the Chevy axle does. You will likely need a different driveshaft.
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| 12 bolt for 10 bolt swap, driveshaft length? | Cousin_Joe | Transmission - Rearend | 4 | 11-08-2007 07:50 PM |
| 3rd Gen F-body rear discs on 65 A-body 12 bolt? | smallblocker2 | Suspension - Brakes - Steering | 7 | 03-22-2006 12:51 AM |
| 1968 Camaro 12 bolt rear end???? | juveteach | Transmission - Rearend | 1 | 05-06-2005 11:24 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
