1968 302 with 289 heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 10:30 AM
A friend of mine sold me an engine he was building to race. He decided to move to a big block so I bought his 302. He suggested I put my stock 289 heads on it however. He said something about the valve size. Does anyone know what I stand to gain from the 289 heads on a 302? Aren't the simply the same heads? I'm guessing the valves are bigger. How will that help me?
Old 07-14-2007, 10:45 AM
289 heads on 302
if they are 65or early 66 with chev style non rail rockers they are better heads most likly smaller chambers than later 302s. but you must use the push rods that go with the heads. valve sise is the same, early 302 rail rocker heads have the small chambers so you must determine what vintage the 302 is. probly as well to leave the 302 as is. cliff
Old 07-17-2007, 11:13 AM
thanks for your help. I think the heads I have are 1968 mfr'd but the 302 is an '82. ...fun to buy parts when you start making modifications from stock.
Old 07-17-2007, 06:16 PM
68 heads. mid year in canada used small chambers with rail rockers that will bolt on, useing your valve train(82 valve train)
Old 07-18-2007, 07:23 AM
fair chance your buddies "valve" comment relates to less valve shrouding on the early 289 heads due to the shape of the chamber which promotes a better burn.....(helps on a high rpm race car, does very little on the street)
irony: over the years the chambers were a bunch of different shapes.....the last 5.0 heads chambers shape was.....same as the original 289!
small chance you already have the small (289) 302 54cc chambers if they are 68' 4V rail rocker heads.....more likely they are 2V 63cc....which with flat top pistons and mild cam puts you at about 9.5CR where you want to be....do a compression test
Cliff's info is dead on......I agree....."just" raising the compression with smaller chambers isn't worth it......
here's a early heads chart to help you figure out which heads you have
Old 07-18-2007, 09:12 AM
Thanks for all the input
I'll be checking it out. I just got the car together, but messing with the heads is no sweat. I'll keep toying!
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
Clevor Boss??? matts94sc Engine 33 01-23-2008 09:51 AM
Good heads for a 65 289 junkyardjeff Engine 20 02-03-2005 07:58 AM
Milling 1978 ford 302 heads CREVISTON Engine 4 09-30-2003 05:12 PM
Windsor Jr. heads on early 302, any problems? 66StangBoy Engine 2 08-21-2003 07:43 PM
