Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-31-2003, 07:15 PM
68redimpala 68redimpala is offline
New Member
1968 327 & Electronic Ignition?
I asked this before but cant find it, how and what do I do to change a 1968 327 over to Electronic Ignition?
Just get one out of a 350 and put it in? or what?
And is this a good or bad thing to do?
Old 10-31-2003, 07:23 PM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
re: 1968 327 & Electronic Ignition?
the chevy HEI is a drop in and very much an improvement. Just ck the pins that the weights go on if you are going to buy a used on. They get worn with age.
Wiring is a simple one wire, 12 volts from the ign switch. Ck your existing wire for a true 12+ volts as some used a reduced voltage coil on the points type distributor.
Mark
Old 10-31-2003, 07:32 PM
New Member
Stupid ? I guess
Do I just go to the junkyard get what year HEI?
I dont use the coil on the car now with the HEI do I?
Old 10-31-2003, 08:45 PM
67malibuEFI's Avatar
67malibuEFI 67malibuEFI is offline
Just find one with a vacuum advance canister and you will be fine. No don't use the coil in the car. You should be able to get a complete HEI from the junkyard.
Old 10-31-2003, 09:49 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
If the HEI is going into a '68 Impala (or full size Chevy) this should not be a problem. In other applications, there might not be enough room because of the firewall being too close. In that case, some "creative" firewall restructuring will be necessary. Trust me, I know!
Old 11-01-2003, 02:10 AM
jimfulco jimfulco is offline
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
