1968 350 starter replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2010, 10:29 AM
We just replaced the reman'd starter with another reman'd and we get a clunk like the gear is extending but the engine is not turning over. I should add that this is the second starter I've tried. The first one turn the engine over for about two seconds. I read a couple problems similar to this but would like to know if it's possible that a remanufactured starter could need shims even though it looks exactly like the one I took off, that didn't have shims. I also read an answer that had to do with compression. Would it make sense to pull the plugs and then try to turn it over? Sorry, I've changed starters before and never run into this situation.
Old 08-21-2010, 10:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It might need to be shimmed. There should have been instructions and even sometimes shims included w/the starter. If not, there are shims sold where you bought the starter, most likely.
Old 08-21-2010, 11:18 AM
1968 starter replacement
No instructions, no shims. I'll go get some and try it. Should I only shim the side closest to the block as some have suggested or shim the whole thing from the get go?
Old 08-21-2010, 12:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
These instructions are what comes in many reman starters. The starter shown is the angled bolt pattern starter nose used w/the "big" 14" (168T) flex/flywheel. Yours may be the starter w/the bolts directly across form each other, used w/the "small" 12-3/4" (153T) flex/flywheel. The procedure is the same for both.
Old 08-21-2010, 01:49 PM
T-bucket23's Avatar
Wiki Edits: 26
If it just goes clunk and is not grinding, I would bet the solenoid is junk. Where are you getting these starters
Chet
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Mini starter on 350 chevy and bolting on. eric32 Engine 3 03-05-2010 07:17 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
350 starter buzz VEGA 3503508.5 Engine 10 04-03-2006 09:36 PM
Starter and flexplate 400 with 350 crank in2classx Engine 2 12-01-2001 08:49 PM
