1968 camaro door - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2013, 02:04 AM
1968 camaro door
can anyone tell me if there is a difference between 68 camaro RS and SS doors.i have a 68 rs.when i brought the car it had only one door on it, it came with another door but was not installed on the car.when i tried to install the door i,m having a hard time lineing it up. So i took a measurement to found one door to be slite larger than the other.
Old 07-07-2013, 04:42 AM
poncho62's Avatar
Wiki Edits: 5
If its from a 68, it should be the same, no matter the model.....How much bigger/smaller is it?....You may have to move the fender slightly
Old 07-07-2013, 06:10 AM
deadbodyman's Avatar
Wiki Edits: 11
same doors...the differences are slight like the rear backup lights. headlights etc
You may have to take the fender off to get at the pillar side of the hinge which moves the door forward and backward.
Old 07-07-2013, 09:11 AM
If the DOOR it's self is more than a 1/16" inch or so in difference I am thinking you have a reproduction door or one that has had a reproduction skin installed.
Reproduction: Similar to original, can be used if nothing else is available.
But really, if the DOOR is a different length that is probably why. But is it the DOOR that is different (did you measure the door it's self?) or is it the fender or quarter that is different making the door fit different than the other side?
You may be able to work with it by moving the fender forward but you really want to find out what is going on, has the quarter been replaced?
The Following User Says Thank You to MARTINSR For This Useful Post:
cyclopsblown34 (07-07-2013)
Old 07-07-2013, 09:12 AM
Even the 67 door though different because of the wing window is same in dimensions.
Old 07-07-2013, 09:32 AM
vinniekq2's Avatar
the 67/68 doors are the same like MartinSr said,except the side draft window.The door panels can vary.
Is this a running car or was it recently? Why was the original door off?Those cars had sub frame issues and fitment might be related to that or it was poorly repaired?
look under the hood and see if the alignment shims are either way too many or none,this is an indication of the subframe issues those cars had.
Old 07-07-2013, 09:56 AM
Before this gets off track how about some pictures to show where you are having issues.As long as the quarter wasn't replaced(hopefully it was done right) like martin says, you should still be able to make it fit the quarter.You need to get the door to quarter gap first followed by door to fender gap, etc.But keep in mind you could possibly lose your cowl panel to hood gap/front header panel gap.Some pics would help to see whats happening.
Old 07-07-2013, 10:14 AM
put up or shut up
yeah, that's what I'd do in a pinch. Just kick it forward and start messing with the front end being mindful that the cowl panel can absorb some of it being you can shim it and move it around, and live with any imperfection there. Sounds like a repro door. Mind taking a pic of the backside or inside of the door?
Old 07-07-2013, 11:26 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Keep in mind you can only move your fender so far forward before you throw the whole front clip out of wack.
Old 07-07-2013, 12:29 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Just another note, Check the hinges......the 68 we are working on has 4 bolt holes in the hinge on the A-pillar side, the replacement door the guy brought, the hinges had 3 holes on the A-pillar side of the hinge (67 I think). Simple enough to fix by changing out the hinges, but just wanted to throw that out there as well. May want to make sure the hinges are in good shape, not bent, pin bushings are good etc, we all know that would foul things up too. Otherwise the 67 and 68 door would interchange minus the vent window in the 67. The 69 had differnet body lines IIRC.
Kelly
Old 07-07-2013, 04:24 PM
There are more differences in a 67 door than just the vent windows, the inner shell where the door panel attaches is totally different from a 68 as the 67 has a half door panel (upper and lower is painted and shows) where a 68 has a full door panel that is all vinyl covered. Still should bolt up the same but who knows???
Old 07-07-2013, 05:04 PM
Git R Done
I've seen GM doors vary by 1/8th inch. One camaro I worked on, the rockers were off 1/4th inch side to side. Never wrecked. Just have to keep moving things around.
Old 07-09-2013, 01:38 AM
68 camaro doors
i measured the height of the door thats not fitting.the front of the door is 1/4 inch to tall , and the back near the door handle is 1/8 " to tall. looks like a new rear quarter has been installed.by the way i compaired measurments of both doors, they are difference.i am thinking maybe a reduction door. i will try and post pictures.Click image for larger version
ID:	75477 The driver side door is the one thats way off. As you can see the passenger side is even with front fender, we just need a little adjustment to this side. will try and post picture of inside of door.
Old 07-09-2013, 04:48 AM
Wiki Edits: 11
Where are you measuring from ?the bottom of the door to the top ? Whats the gap at the bottom of the door and the rocker look like . show pics of all three gaps front,back and bottom so we can get a good look.
I've had them start out that bad or worse when reassembling after the hinges were removed but after a few adjustments they usually fit pretty well ....
Old 07-09-2013, 08:05 AM
Originally Posted by quick 54 View Post
i measured the height of the door thats not fitting.the front of the door is 1/4 inch to tall , and the back near the door handle is 1/8 " to tall. looks like a new rear quarter has been installed.by the way i compaired measurments of both doors, they are difference.i am thinking maybe a reduction door. i will try and post pictures.Attachment 75476
Attachment 75477 The driver side door is the one thats way off. As you can see the passenger side is even with front fender, we just need a little adjustment to this side. will try and post picture of inside of door.
In that first picture the problem looks to be more in the fender and not the door. Yes the door looks high, but the fender is REALLY making it look bad because it's so low. How close is the door to the rocker at the front?
1968 el camino door panels riverkds Body - Exterior 2 03-28-2013 05:53 PM
1968 Buick Wildcat 4 door Sedan Christopher Floyd Introduce Yourself 3 12-22-2011 01:00 PM
1968 Mustang Coupe - door skins geeky2 Body - Exterior 9 11-17-2010 09:50 AM
1968 Firebird Door Panel Top Rail 68Birdman2 Interior 3 02-04-2010 07:23 AM
1968 Camaro Door Panels.... mrvanhan Interior 3 08-26-2003 01:59 PM
