1968 camaro swap
I have a 1970 monte carlo 12 bolt rear, I currently have a 10 bolt non posi rear in my 1968 camaro. Is it possible to install that rearend in the camaro? If so what kind of motifications am I looking at? I realize that they have two different spring systems. If not what is the cheapest or common rear should I put in this car? 1968 nova rear?
The Nova rear will bolt in....the Monte Carlo is too wide
Ontario Rodders |
Vince |
You can get universal spring pads from Jegs.I had to find a rearend real fast one time and took one out of a 4dr 1971 Chevelle.Cut of old mounts , put on pads using old rearend for measurement purposes.Everything went together fine.I've got a 1970 Nova.Chevelle rearend was a whole 1 inch wider
I still had room for my 8" Ralleys and 60 L60-15 tires.I would think the Monte and Chevelle rear would be the same size but I don't know. |
The 8.5" rear is nearly as strong as a 12-bolt, and one from a '72-'79 Nova or clone will be the same width, with the spring perches in the same location as yours. '73-up and '72 SS cars will be set up for multi-leaf springs.
You might need to have your driveshaft shortened a little bit, since the U-joint on the 8.5" is a little farther forward of the axle centerline. Try the old shaft first, though, because you might just get lucky. |
| engine swap in Camaro | STATUTORY GRAPE | Engine | 3 | 06-19-2008 11:56 PM |
| Camaro rear swap | V305 | Transmission - Rearend | 7 | 03-29-2008 02:51 AM |
| 1967 firebird with 1968 camaro | eroc_d | Body - Exterior | 3 | 11-04-2006 11:37 AM |
| 1990 RS Camaro TBI to TPI swap | Camaro2Fast4u | Electrical | 8 | 01-03-2005 08:42 PM |
| forth generation camaro nose swap | squeak3876 | Body - Exterior | 1 | 06-24-2004 06:57 PM |
