1968 Chevy Big Block labor questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2005, 06:19 PM
How many hours should each of these jobs take a professional to do?
* removal of an old fuel pump and replace with a new one
* installation of a new thermostat (and gasket of course)
Old 12-05-2005, 07:44 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
My best estimate would involve more info here. As in, what kind of vehicle? Some can be done in 20-40 minutes, and I'd bet that most guys on here have had those days when it can take a solid weekend. Heck, I've got a '97 C1500 5.7 Vortec that I can change the waterpump in 1 hour flat.
BTW, this probably belongs in the general rooding tech section, not the garage tech. Not trying to be a stick about it.
In a while, Chet.
Old 12-06-2005, 09:25 AM
if its just a big block setting on a stand, the thermostat should take about 5 min, 2 bolts? thiss only if they come out, if they dont and you break them your looking into more time.
Fuel pump, mechanical or electric? I'm guessing that because of age its mechanical and sitting right on the side of the engine, 2 bolts again. most newer cars have electrical that are located in the gas tank and you can't reach them without dropping the tank.
Again i'm assuming the engine is out of the vehicle, but if not it still shouldn't take that long on and older car like you said
Old 12-06-2005, 02:02 PM
35chev/302gmc's Avatar
To re & re a thermostat housing, clean old gasket, replace t-stat and fill & bleed cooling system should be .5hr
To replace fuel pump 1.0hr
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
Chevy Big Block 454 Marine heads 71 nova Engine 4 09-03-2004 06:08 PM
Big Block in a 51' Chevy oldford Engine 1 03-26-2002 06:32 PM
big block chevy fit in 1954 truck pkaszuba Engine 3 01-03-2002 07:08 AM
