Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1968 firebird , highway RPM way to high
  #20 (permalink)
Old 04-09-2013, 11:40 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
You do have a tach, correct...what you could do, again, put the car in drive, watch your tachometer, you should see your RPM rise and drop twice...if the RPM's rise and drop from 1st to 2nd and then from 2nd to Drive...then you have all three gears. If it only does it once, then you are probably running in 1st and 2nd gear only.
Another way to tell is by listening to the engine, the same thing should happen, you will hear the engine rev up and then hear it drop and rev up again and drop...On a three speed automatic this should happen twice. If it's only happening once, you'll need to get under the car and adjust the shifter linkage.
Ray
