my engine has those. if you look close at the pic of the head the fire ring from the head gasket is barely touching the head between cylinders, and the ring is actually partially in the combustion chamber. why couldn't i go with a head gasket with a slightly larger bore size, as i would think it would make the rings larger in diameter and move it away from the edge of the chamber? here are some examples of felpro head gaskets
PONTIAC 6.6L/400 Head Gaskets - SummitRacing.com
