1968 GTO upper control Arm bushing replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 06:19 PM
adam83's Avatar
This will be my first control arm job. The bushing in the rear side of the passenger upper control arm has been destroyed. The rod still looks good, but I wont know until I take the arm off. I'm taking off both upper control arms and I am assuming that I will at least be needing ball joints along with the bushings, and I might have to get new control arm shafts. I wont know about the shafts until the arms are off. I was thinking if I need both, I might get the MOOG kit, which also comes with all the hardware too. I was also looking at polyurethane bushings, but I am on a very limited budget (I spent everything on the engine...).
My question is, and it is very green, but do I need to put a jack stand under the lower control arm when I start removing the upper? I just have the basic tools, such as socket sets pry bars, allens, torx, hammers, punchs, etc etc but I dont have anything like air tools or a spring compressor. The only thing that worries me is will I be able to get the arm back when the new bushings are installed, with out a spring compressor or special tool?
Old 11-19-2010, 07:15 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I would put the jack stand under the frame, right behind the tire. Use a floor jack under the lower control arm to support it, no need to remove the spring and as long as the shock is still in place the spring can not go anywhere. The shock will limit the downward travel of the control arm and it (the shock) is inside of the spring.
Old 11-19-2010, 07:23 PM
adam83's Avatar
cool, that takes away a lot of worry for me.
Old 12-19-2010, 07:53 PM
I think you need some special tool to be able to get the arm back when the new bushings have installed. PM me if you need some assistance.
Old 12-20-2010, 08:19 AM
Leave the shocks in place, so there is no way for the spring to come out. Once you get the arms off, you need to either press the bushings out or burn the rubber and compress the shells to get them out of the arms. Be sure the shaft is in place inside the control arm BEFORE you start pressing the new bushings in place. Do not torque the nuts (or in some cases bolts) on the ends of the shaft until the arm is in place and the weight of the car is on the suspension.
Old 12-20-2010, 11:23 AM
adam83's Avatar
I think it's cool that this advice has come when I needed it. I've been painting the inside of the house for a month and have had no time for the car, but I will soon. Now, when you say leave the shaft in place before putting on the new bushings... do you mean secured to the car? Because I thought the control arm and the control arm shaft needed to be off the car to get the new bushings on.
Old 12-20-2010, 01:00 PM
No, what I meant is be sure the shaft is slid into the holes in the control arm before you press in even the first bushing. I've has some upper arms where the shaft needed to be inserted from the middle of the control arm - in other words, insert one end into the arm, slide it until the wide part for the mounting bolt hits the inside of the arm, then insert the other end and center. If the wide parts of the shaft won't pass all the way through the holes in the arm, you can't insert the shaft with the first bushing in place.
replacing control arm and body bushings elcaminodragster Suspension - Brakes - Steering 10 09-01-2008 06:07 PM
B-body spindles for 70-72 A-body? Crow44 Suspension - Brakes - Steering 11 11-07-2007 07:52 AM
71 Chevelle rear control arm bushings 454me Suspension - Brakes - Steering 4 04-23-2005 09:46 PM
Control Arm bushing replacement bonuts Suspension - Brakes - Steering 7 03-14-2005 08:06 AM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
