1968 gto wiring issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2011, 03:01 PM
I have 1968 gto wiring problem,the tail lights,brake lights and turn signals work fine until i turn on the head lights, The blinker stops blinking inside and outside front and rear, also the brake lights will not come on brighter when i press the pedal. Has anyone had this issue
Old 04-07-2011, 06:13 PM
LATECH's Avatar
you have a bad or missing ground somewhere. Check/clean them all.Start at the battery with the one that goes to the body and work your way back.
Make sure you have one from the engine to the body also.After that you should have cleared up a bunch of the problem, then go to the individual bulb and clean/check them for bad grounds or bad sockets at the bulbs that are still not functioning correctly
Old 04-07-2011, 06:21 PM
ogre's Avatar
the 'Duracell Project'
your tail lights and brake lights have nothing in common other then they're on the same car.
first off i'd start checking grounds, use a test light or meter to see if you have power at the lights.
then check the output of your tail lights at the switch; on and then with the headlights on.
your brake lights and blinkers are on the same circuit.
do the same test to see where the power quits.
you could have a couple of problems or a single ground that is messing with you.
Old 04-08-2011, 03:44 PM
1badLemans's Avatar
Funny I have a 69' lemans that i just fixed a brake light wiring issue similar to yours a couple of days ago. Yes i had a bad ground where the light socket meets the ground "chain" link. I used a red scotch bright and bingo, they're working.
1968 gto wiring help needed adam83 Electrical 22 02-26-2011 04:48 PM
alternator wiring issue. 56dodge Electrical 4 08-19-2010 06:02 PM
87 GMC wiring issue TurboS10 Electrical 9 06-19-2009 05:23 PM
wiring issue gilby246 Electrical 2 03-20-2006 09:57 PM
Wiring diagram for 1968 442 bear1968 Electrical 2 01-27-2005 03:47 AM
