1968 Mustang Coupe - door skins
Hello all,
can anyone suggest a good source for door skins for a 1968 Mustang coupe? FYI: in a previous post of mine, i asked about a source for a RH / PS inner fender apron. in the replies that i got back (which were really great!) - someone suggested NPD (http://nationalpartsdepot.com/), which i will use as a source for the apron. thank you for any and all suggestions. thank you mark |
Just looked on goodmark site and they show shells for $309.00 but I don't see skins on the site.
But of course I would be thinking long and hard about NOT changing the skin but repairing yours. Door skins are tough for many professional bodymen, for a first timer it can be a disaster. And this is with quality OEM skins, if we are talking about your typical aftermarket made in China junk, it can be maddening for anyone!
It may be the best choice, but look at it long and hard first. What is the reason you want to change the skin? If you do decide to go with the skin, here is a little tutorial to door skins. "Basics of Basics" Door skins Brian |
one door is wavy. and the other door has quite a bit of bondo in it. both doors "structurally" are very sound, eg NO rust spots in or out (that i can tell) i have the glass pulled from the doors. i am really glad i asked some questions up here. i had gotten the impression from other (on-line) sources that doing this in an 68 Mustang Coupe was pretty easy? 1) i suppose i could take the doors to a shop and have them fix the existing doors or put skins on them or 2) i could buy new door shells. i have checked the costs on these. they look to be ~350.00 per shell. my goals for the car are pretty simple. learn / do as much as i can but also have the car look fairly decent when i am done. i have started the process by completely stripping the car to metal and putting it on a rotisserie. thank you mark i suppose i could take the doors an |
hello martin,
thank you VERY MUCH for the info. i GET your message ![]() thank you mark |
I would have to agree with MARTINSR I would use the doors you have the aftermarket ones dont fit like OEM doors and in most cases you have to bend and hammer then you still end up using filler
68 mustang door skins
I am in total agreement I would keep the original. I had rust holes in my 68 fastback doors. I cut a 3 1/2" to 4" strip out across the bottom of my doors and weld in universal door bottom metal. If i had a sheet metal brake I would have made my own. aftermarket panels can't compare to the original. Now this may sound funny, but when I would cut out rust from a car and throw the rusted metal on the floor it had a sound of a slight ring, but when I trimmed an aftermarket panel and throw the trimmings on the floor it was a dead sound, the original metal was stronger than the aftermarket. I bought full floorboard panels for my 68, after getting them ,I decided not to use them because of the cheapness, instead I used 16 gauge metal. If your doors are rust free, there is no way you should replace them. If you want to repair them yourself find a good body man get all the info you can , give it a try and take the doors to him to check out. The way I learned, I hung out at a body shop after school and they let me do little things like clean up, then sanding and taping. I did this all free just to learn. My first repair was a 57 chevy door took 3 days , now it would take me 45 minutes to repair that same dent.
Good Adivice Given,
+1 on repairing the doors if possible. I have found that building a 67 Mustang from oversees parts is very challenging. EVERY part needs masaging and some just aren't right. Noel |
| BBC 454 in 88 mustang coupe | MOORESPEED | Engine | 26 | 12-21-2010 08:45 PM |
| 66 mustang coupe chop top??? how?? | jackbh | Body - Exterior | 8 | 12-26-2006 09:40 AM |
| New Project - 70 Mustang Coupe | Arrowhead | General Rodding Tech | 4 | 10-11-2006 05:45 PM |
| 1968 Mustang Patch Panel Problems | MrJohnnyUtah | Body - Exterior | 3 | 06-09-2005 08:40 AM |
| 1968 Mustang Timing | Rvornhagen | Engine | 2 | 01-12-2005 09:52 AM |
