1968 Mustang Patch Panel Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2005, 05:01 PM
I am in the process of restoring a 1968 Mustang Coupe and am in need of a little help. There is a small amount of rust on the front quarter panel on the passenger side, right infront of the rear weel. I can find small patch panels for the 65/66 but can't locate one for the 67/68. Is this part not in existance or will the 65/66 part work? Thanks in advance, this is my first rebuild and I am reying to do it as quickly as possible, I know that this is not usually advised but I do have a limited time frame i'm working with. So far so good, when I bought it the drivetrain was almost all brand new all it needed was cosmetic TLC and so far thats all I can see that she really needs. Check out my web page for pics!
http://www.cardomain.com/ride/806192...5&val=1&page=1
Thanks,
John
Old 06-09-2005, 05:59 AM
rusty428cj's Avatar
How bad is it? You could make a patch or buy quarter panel wheel flare replacement that sells for $29.95 from NPD
Old 06-09-2005, 08:03 AM
Rich_Long's Avatar
Old Mustangs are to hotrods!
Last journal entry: 68 Mustang Fb
http://www.parts123.com/PartFrame.as...=CJ_Pony_Parts
You'll want the "wheel flair" in the body section.
Old 06-09-2005, 08:40 AM
If it is rusted through in that spot chances are good you will find more rust inside so why not check out a q-panel skin? They are cheap and not much more work than a patch.
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 08:27 PM
Question on welding patch panels? sled51merc Body - Exterior 39 01-30-2005 11:56 AM
patch panel for f-100 qckshftn56 Body - Exterior 2 02-26-2004 05:27 PM
Patch panel replacement on frame or rotisserie? GMW Body - Exterior 2 10-08-2003 06:15 PM
More patch panel questions. Gassman Body - Exterior 4 04-14-2003 08:38 AM
