1968 Mustang - replace PS inner fender apron - battery corrosion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 08:16 PM
geeky2's Avatar
1968 Ford Mustang - beginner
Last journal entry: garage work
hello all,
i have a 1968 Mustang Coupe.
question: can someone provide tips or suggestions on a good aftermarket source for a Passenger side inner fender apron?
mine is suffering from years of corrosion (from the battery).
i have read one on-line article on how to do this. the article also provided a source for the "sheet metal" replacement part.
i have also read that many of the after market sheet metal parts, vary GREATLY with respect to quality and fit. i would really appreciate any advice or source information from someone that has been down this road already
thank you,
mark
Old 10-27-2010, 12:57 AM
JeffB's Avatar
Arizona Muscle Mart on 59th Ave in Phoenix,AZ has a large stock of used donor Mustangs and will probably be able to hook you up,anyway have them send you a catalog they also have new parts.
Old 10-27-2010, 06:36 AM
NPD has repopp inner fender aprons. I am in the same boat as you and am about to do this same repair.
I bought the cheaper apron because the consensus on Vintage Mustang Forum was that had the better fitment.
It is only about 30 bucks.
Check out a blog of a guy who did this. He writes very well and provides good pictures.
AOLSHOVE BLOG
He also talks about which repop piece to buy.
PS. Spent a lot of time in Belvidere, IL a few years back when I was working for Chrysler traveling to the Assembly plant there.
Old 10-28-2010, 01:20 PM
geeky2's Avatar
thank you VERY MUCH for the great feedback.
thank you
mark
Old 10-28-2010, 02:35 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may wish to try car-part.com as you may be able to source a usable part there locally..
Sam
Old 10-30-2010, 07:25 AM
I replaced all my aprons on my 68 fastback, make a drawing of engine compartment and measure, measure, measure, make sure everything is fastened in place so when you remove battery apron nothing moves. i tried using spot weld cutters, junk welds too hard. what i did was drilled a 1/8" hole thru the center of the spot weld and then used a 3/8" drill till it reached the outer circle of the spot weld and broke the weld loose. the 3/8 left a counter sink spot where i drilled, when i weld the apron in place i filled in the counter sink hole, looked like the original spot weld
Old 10-30-2010, 10:23 AM
geeky2's Avatar
thank you for the feedback.
question: when i remove the RH inner fender apron - is there a danger of something moving?
if so - what / how do i anchor things in place (so the rest of the components do not move).
thank you.
mark
Old 10-30-2010, 08:05 PM
from the top measure the inside distance of engine compartment width from left front apron to right front battery apron. write down the width. measure inside from right fire wall lip to radiator housing, that way you have the correct inside length and width. clamp in place and weld. i used metal screws, then removed after welding and spot weld the holes that the screws made. installing one apron will be easy. i installed all 4 plus front frame rails, got pretty hairy but i took all kinds of measurements from different points made braces and jigs to set frame in, all came out o k . hope this info helps
Old 10-31-2010, 09:46 PM
geeky2's Avatar
yes - this really helps!
thank you,
mark
1968 Mustang Wheel issues. theblackduck87 Hotrodding Basics 1 08-08-2010 06:02 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
1968 mustang coupe burgerman Introduce Yourself 23 12-17-2005 08:49 AM
