Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1968 Pontiac Firebird 350, which headers?
Old 04-12-2013, 02:07 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
If your main concern is the ease of the header fitting, either Hedman or Hooker are in the top brand names for headers, in my experience, the amount of power gain when installing headers is going to be reflected with how much exhaust your pushing through the engine. For example, you would get a bigger increase in performance if you had your heads ported and polished than if ran stock heads because your engine can produce more flow...if your running a Pontiac 350 with a 2 bbl Carb, you would get less performance from your headers than if you where running a 4 bbl Carb with an upgraded camshaft.
I've used both Hedman and Hooker on Pontiac engines and have had good results.
Hope this helps.
Ray
