1969 350 375HP GM Goodwrench Replacement Engine
I just purchased a 1969 350 375HP GM Goodwrench Replacement Engine (real cheap) from a guy (2nd owner) who never got around to using it. He said he was told by the person he got it from that the engine had to keep the heavy steel double pulley on the crank because it was balanced from GM that way. Does that sound correct. I want to put it in my 1967 Opel Kadett to mock up and make a few run s to get the chassis worked out. But I want to take that double pulley off. Will that cause any problems with the engine. When I am done using the engine I have a Kid who wants to buy the engine. I don't want to hurt the engine but I need to remove the pulley for clearance reasons.
As a side issue. Any quess on what I can expect in the 1/4 with this engine?
1700 lb car with engine, aluminum glide , 8 3/4 rear ( not sure of the gears, I just bought the roller 2 weeks ago) ladder bars and a large driver.
Thanks for all replys
Tom aka Big Daddy Teez
