#1
1969 396 2 barrel engine is it worth anything?
A friend of mine is trying to sell me a 396 and a turbo 400 out of an impala. The motor is complete 2 barrel carb to pan and has the original turbo 400 with it. Is it worth any thing never heard of a big block with a 2 barrel. I looked on ebay and could not find any stock 2 barrel intakes. Only thing I could find on line is this.
L-66 1969, 396/265HP, 2-bolt block, steel crank, cast pistons, closed chamber oval port heads, hydraulic cam, compression: 9.0:1, 2 barrel carb, cast intake Is it worth any thing or should I keep looking? Register now (free) or login to remove ads |
#2
It`s worth whatever anyone will give you for it. However, the question on big blocks is common, why spend money on a 396 when you can build a 454 for the same price?
#4
Yes, 396-402 two bbl full size cars were produced in 69 and 70.
I owned one of those beasts back in the day. What a TURD!!!!!! Parted it out when the front end parts got loose. If you can get the engine/trans combo for a good price. Grab it. The intake, cam, exhaust are normally replaced on a Hot Rod rebuild anyway. |
#5
Yes, easy to make that into a 400hp/450ftlb 402cid (+0.030 396) with a cam, intake, carb, and header swap. However, as stated above, why build a 396 when you can build a 454 for the same price?
I built a 396 as a spare engine for my 454. Had it sitting under the work bench so I used it. It is now a 413cid. It works OK as a spare but is down on power and gets 1 mpg worst as compared to my 454. |
| Thread Tools | Search this Thread |
| Similar Threads for: "1969 396 2 barrel engine is it worth anything?" | ||||
| 425 olds good engine? worth anything? | Jared | Hotrodding Basics | 18 | 04-11-2012 02:04 PM |
| crate chevy 302??? | Vancouver Grand Prix | Engine | 92 | 05-07-2010 06:25 PM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| chevy 396 truck vs car engine | MPCzehura | Engine | 4 | 11-28-2006 09:07 AM |
| will a 1969 455ci olds engine bolt right in place of a pontiac 400??? | chevyelc81 | Engine | 3 | 06-12-2002 03:54 AM |
