1969 camaro ammeter - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2006, 04:22 PM
1969 camaro ammeter
i have been told 69 camaro ammeter is not a true ammeter and the wiring is different than traditional ammeter. my wiring schematics are gm but do not show ammeter only charge lites. this ammeter as wired in series shows 0 amps with key off , but dome light pushes meter to 20 amps adding the console courtesy light pushes it to 40 amps. my inductive fluke meter shows a current draw of 1.5 amps with dome and courtesy light on. any help is appreciated
Old 07-18-2006, 04:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
It's a Differential Voltage meter, If the wiring is unmolested:
The black wire goes to a fuseable link that connects to the junction block behind the battery. The black/white wire goes to a fusable link that connects to the horn relay. Both wires should be 14 ga.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
1969 Camaro Shifter And Trans Installation Help JimKramer Transmission - Rearend 2 05-01-2006 07:14 AM
1969 Camaro, CDRITTER Introduce Yourself 1 12-02-2005 11:04 AM
X33 or X77 1969 Camaro Identification JimKramer Hotrodders' Lounge 0 09-02-2005 10:33 AM
1969 Camaro Tach Installation Help daveh Electrical 2 02-09-2005 11:54 AM
1969 Camaro Tach daveh Electrical 2 01-27-2004 06:49 PM
