1969 Camaro Dash Lights Out - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2005, 08:07 AM
daveh's Avatar
Hey guys,
I am still trying to fix my dash lights. Here is the situation I have no dash lights except for the lights in the heat/AC controls it works fine. I have done all of the following with no luck: HELP
1. Replace the light switch, yes the ground on the switch is connected and clean.
2. The bulbs have been replaced
3. The lighter is not hooked up so there shouldn't be any kind of interference there.
4. The fuse is good
Any help is always appreciated.
Dave
Old 07-02-2005, 10:05 PM
docvette's Avatar
Wiki Edits: 12
Cluster
Doc here,
Be sure your Instrument cluster had a GOOD ground.
next, go to the AC/Heater controls..do they dim as advertised? Then troubleshoot forward, you'll probably find an open wire between there and the cluster..
If all else fails, you can abandon the current cluster dimmer and bypass it to the AC/Heater lamps..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
1969 Camaro idiot lights JeffShuman Electrical 5 09-02-2004 02:40 PM
dash lights and turn signals - again SteveMach1 Electrical 2 12-13-2003 10:22 PM
Dash lights fade in and out firebirdfanatic Electrical 10 10-02-2003 08:27 PM
1969 Camaro dash lights out follow-up daveh Electrical 8 06-18-2003 06:25 AM
1969 camaro dash lights out daveh Electrical 7 06-16-2003 06:26 AM
