-   -   1969 Camaro Emissions (http://www.hotrodders.com/forum/1969-camaro-emissions-4070.html)
PrimaDude 10-19-2002 06:31 PM
I just bought a rotisserie restored 69' Camaro RS/SS 396. The car is restored completely to factory specifications. I have been looking at Colorado's emissions program as I will be required to have the vehicle pass or spend money to try and pass and if not, get a waiver, in order to get the tags for the car. I don't want some kid at a required Colorado sanctioned air emissions repair facility screwing around with the engine/carb to get it to pass. Has anyone had experience with doing this and what should I expect? I am wondering if they force you to spend money on a catelytic converter or some other bogus emissions hardware. Can anyone give some advice?
78 monte 10-19-2002 08:25 PM
As far as I know everything that was on the car factory must be there.In your case if its a non-Ca. car I think you need a PCV,the origanal aircleaner,and the right vacuum line hook ups.I think evan headers are legal cause theres no Cats and duel exhuast was factory.If it had a heat riser tube for the air cleaner thats required.
With a good tune up and as long as you don't have crazy race parts(9,000,000duration cam etc..) I think you'll pass.If not steal some plates and drive it anyway!!!!
cyrus-j 10-20-2002 05:10 AM
I'm not sure about Colorado's laws but in many states a 1969 car would be considered an antique and would be exempt from emission laws.
Some states also have hobbyist plates that exempt your car from testing.
PrimaDude 10-20-2002 06:51 AM
Thanks for the info. The engine is a new rebuild so I guess I shouldn't really expect any major problems unless something is missing that I don't know about. I guess I need to buy a factory engine manual.
Joe
