1969 camaro rear brake problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2007, 10:53 PM
1969 Camaro owner
Hey, hopefully you guys can help me out here. I've got a new master cylinder and line lock system installed. I bench bled the MC and installed it on the car, bled out the entire system. My pedal still goes to the ground, its not even "spongy", its worse! I cannot "pump up" the brakes like normal, just goes to the floor. The front brakes and front line lock are working perfectly but the back ones do not lock up at all and they are both adjusted correctly. When I was bleeding the rear brakes, I was watching the reservoir level and its fluid level was barely noticeable as far as movement. I've got speed bleeders all around as well. All lines and connections are good, no leaks, no pinched lines. What the heck is wrong with my system? oh yeah, system is stock front disc, rear drum if that helps.
Old 07-24-2007, 06:39 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I need a little more info please.
was this system working before you modified it?
What is a "Speed Bleeder?"
Have you checked all the lines to make sure the lines a clear
When you bench bleed the Master did you have the return lines in the fluid so it will pump & suck @ the same time?
If the front is working that is what you want ..right ...to lock the fronts so the rears can spin freely to heat up the rubber?
R
"SlowRide66"
"Illegitimis non carborundum"
Old 07-24-2007, 11:40 PM
1969 Camaro owner
ok!
no, the line lock install didn't affect it.
a speed bleeder is a bleeder with a ball check valve to prevent air from being sucked back into the system.
yes
yes
yes, also for preloading the drivetrain at the line.
Old 07-25-2007, 10:02 AM
Rob Keller's Avatar
Wiki Edits: 38
Has the master been sitting not wet for a long time ?
If so its bad rebuild /replace IMO
R
"SlowRide66"
Old 07-25-2007, 08:19 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I had a similiar issue when I did an entire brake system rebuild on my old '84 Chevy truck. It had no brakes at all before I started. I had no pressure whatsover to the rears, and the fronts where very light on holding power. I solved my problem by looking for that little "juction block" that is mounted to the frame that all the lines then head out to the wheels from. There should be a small "peg" or button-looking pin that just needs pushed back in. At least that's what worked in my situation.
Hope that helps, Chet.
Old 07-26-2007, 05:21 AM
1969 Camaro owner
Well I bought it dry from a parts store. When I bench bled it the rear did take a lot longer than the front, they should both be about the same speed during that initial bleeding right? I installed it the same hour I bled it and used the caps but it did take about a minute after the caps came off to attach the lines.
My distribution block has an adjustable pressure differential valve in it but I'm not going to mess with its setting, that shouldn't affect the volume of fluid just the timing of the front/rear.
Camaro rear end advice gavinpierce Transmission - Rearend 2 08-09-2006 02:17 PM
Locating An Oil Leak In My 1969 Camaro daveh Engine 4 04-28-2006 10:28 AM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
73 Camaro 12 bolt rear end???? 406chevelle Transmission - Rearend 3 03-12-2006 10:07 PM
1969 camaro ignition problem dawg Electrical 3 06-16-2005 05:37 PM
