1969 chevelle body off resto - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-04-2005, 07:02 PM
I am in the process of trying to remove a brand new,perfect headliner from my car and do not want to screw it up. Interior and upholstery are not my strong suits. I dont understand how it is fastened around the edges after you remove the piping { or whatever its called}.
Old 08-04-2005, 07:07 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome to the board. You are new so don’t know the ins and outs yet. This forum is intended for general introductions only. Tech questions posted here don’t get the coverage they deserve. Repost your question in the interior forum and it will have a good chance of being answered. Read the Newbie threads at the top of every forum for lots of good site info like this.
Old 08-04-2005, 07:11 PM
rrmccabe's Avatar
GM Muscle
I am not an expert either as I have never removed a 69 chevelle headliner. But I think if you remove the "U" molding along the sides you will find it is just hooked around the metal lip that the U channel goes around.
I think it will be easy to see as soon as you pull that channel molding.
Rich
Old 08-04-2005, 08:04 PM
69 chevelle
Thanks for the info. I had the "U" off but didnt want to tear anything. Thanks for the help. I cant type worth a flip!
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
1969 chevelle Doogle Barnes Interior 4 08-31-2005 02:18 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 02:15 PM
1966 chevelle to 1969 el camino 12 bolt swap 69elcaminoss Transmission - Rearend 3 03-30-2004 09:02 AM
Where can I get a 9 inch rear end for a 1969 Chevelle? YenkoChevelle 69 Transmission - Rearend 7 07-10-2003 12:02 PM
