one last thing,,,,,,
thanks for the quick response, when I use the dwell meter, the red will go on the positive side, the black will go to ground, but not a ground on the coil. correct???? thanks alot, you guys are saving me a ton of money with your help and advice. JEff J. 69 Camaro owner,,, basket case really lol
It depends on the dwell meter you have. Some had 2 leads, others had 3. With a 3 lead, IIRC, power and ground as normal, and the third lead to the coil negative. Dwell is measured off the coil negative, as the points switch on the ground side of the circut.
Jeff, did you get that oil leak figured out?....Inquiring minds want to know.........
Ontario Rodders |
leak
hey poncho, yes, and thanks for asking, don't know if it was the wrong oil filiter, deftective oil filter, or something I did. But it was blown out at the top. 4quarts were out of the engine. I had to drain the oil to see how much I had to add. Good thing I had bought another 5 quarts. The oil filter the guy sold me the first time was only about 1/2 has tall as the one I had always used, about the size of the one on my 94 f-150 also. But he told me the small size was new technolodgy, I think he gave me the wrong one. Anyway, I let the car run for almost 30 minutes tonite. Still need to set the timming and dwell.....
One more thing, is there an esay way to find your posts on here? I do get messages in my e-mail, but I wanted to up date you on the leak I had Sun. and couldn't find it. thanks again Jeff J. |
Ontario Rodders |
type in your user name.>>>>>.click "GO" Anything that you have started or posted in should show up |
| 1969 Chevy truck ignition | ViolentKor | Electrical | 1 | 04-27-2008 09:50 AM |
| Fan hit upper rad. hose!! | mustangdude947 | Engine | 14 | 08-19-2004 03:52 PM |
| Side Pipes for Chevy Truck | Mr.56Chevy | Engine | 5 | 01-12-2003 07:34 PM |
| 55 chevy side motor mounts | Dave Y. | Engine | 2 | 01-01-2003 06:13 AM |
| Side mounts on a 56 chevy | onelac | Engine | 0 | 10-13-2002 08:00 AM |
