Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1969 Firebird, panhard bar with leafsprings?
Old 01-06-2013, 03:51 PM
Jake Brake Jake Brake is offline
And if you use a panhard bar on parallel leaf springs it will bind. Absolutely no need for it. Sway bar make it so you can disconnect it too see if it helps or hinders. Most need a beefier front bar
