Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1969 Firebird, panhard bar with leafsprings?
Old 01-06-2013, 04:00 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I agree with JakeBrake. Do not use a panhard bar with leaf springs.
A panhard bar pushes the axle left and right, because it is fixed to the frame and rotates around that point. Panhard bars are typically used on coil spring suspensions, and tranverse leaf applications.
A watts link would be better, but still shouldn't be needed on a parallel leaf spring application.
Why are you wanting to install a panhard bar?
