Maryhill Hill Climb Last edited by aosborn; 01-20-2013 at 07:10 PM. Reason: typo |
I see a lot of book-reading here but not so much book understanding, and the meaning of "bind" is pretty-much lost in the wind along with where arc does and does-not mean anything. Said as a guy who canyon-raced for years and has built both coil- and leaf-spring cars. Just how much difference there is dialing in roll stiffness using sway bars on the different suspension types would be enough to let someone suspect what's going on when leafs are working...then if you take some actual measurements you might have actual knowledge. "Just saying". Anyhow, you got the "roll-understeer" thing, which is something that most people don't have a concept of. |
Look at the cars in my photo album and my avatar. Those are not theoretical, and they did not build themselves. There are plenty more where they came from.
What I am trying to do on these forums is to present a very complex subject in a way that is informative but not too heavy. If that is all you got out of my comments regarding leaf spring bushings and suspension binding, then you missed the point completely. If that is because I didn't explain it well, then my bad, if it is because you just didn't understand it, well...I tried. Have a good day. Andy |
So...what is it about? This is helping? Later. |
Brian |
Only thing I was trying to point out here is.. By adding the panhard bar to fix one problem, Does it also create another one ???
![]() Weighing out the real true benefits with a leaf spring set up.. I know Andy has some knowledge in chassis's,, But in the end is it worth the trouble to gain very little...
Same here. I understood, just didn't agree. That's what these discussions should be about, not about a contest to see how many will attack or flame.
I still think that the normal travel of a panhard bar is an arc, and as such it will try to push/deflect the springs sideways as the rear travels up and down. It's just not something I'd ever put on any of my vehicles. If it's done because clearances are at a minimum, then those clearances must be enoughh that the arc of the panhard bar's travel wont push or pull the axle and create a further clearance issue. By the way Andy, your build cars are amazing! |
SLO_Z28 1974 Z28 Camaro Autocross Test n Tune 2-4-12 - YouTube
Camaro...with leaf springs... In the words of Forrest Gump... "that is all I have to say about that". Thank you all for you input and insight. Regards, Andy |
I would say someone needs to check that car out...
Brian |
Umm hmm, it's a good video. At a vantage point about 12-14" above the stock roll center, it illustrates the result of body roll and a little bushing squirm. If what you really want is for the tires to not move sideways in relation to the body, you could use a panhard rod or watts link to raise the roll center but then you're back to fighting the leaf springs again and it will get skittish over bad pavement on corners. A better solution for the car shown would be stiffer (or just new) spring bushings and more roll stiffness via swaybars or spring rate.
But anyhow, I think we're all tired of this one and I'm not going to get anywhere with it. For the original poster, see some light-but-knowledgable discussion pro/con specific to the panhard bar issue here: Panhard Rod on a Leaf Spring Car |
| The Following User Says Thank You to kso For This Useful Post: | ||
Nuck Chorris (01-23-2013) | ||
| panhard bar. | elcaminoman69 | Suspension - Brakes - Steering | 2 | 03-28-2010 12:58 AM |
| wish bone, panhard bar, track bar | BigBlockT | Suspension - Brakes - Steering | 6 | 02-11-2010 10:25 AM |
| 4 bar & panhard | blackbart | Suspension - Brakes - Steering | 41 | 11-24-2009 07:33 PM |
| panhard bar uncertainty | crackfiller | Hotrodding Basics | 1 | 04-03-2007 04:06 PM |
| Panhard bar revision | 5window | Suspension - Brakes - Steering | 2 | 11-06-2003 04:31 AM |
