-   -   1969 GTO 400cid engine mystery (http://www.hotrodders.com/forum/1969-gto-400cid-engine-mystery-229800.html)
Rosylab 02-20-2013 06:25 PM
I'm driving myself nuts trying to figure out what the engine in my 1969 GTO is all about. Here's my dilemma---all of the casting numbers on the block seem correct for a 1969 400cid (i.e. Type code YS,Date code B289,Feb 28,1969,casting number 9790071, production # 0599899) except there is no VIN number stamped on the block front next to the timing chain cover like there should be. There is a nicely machined pad but no number stamped on it! Did some factory engines miss getting the VIN stamped on them or what? All the other component numbers seem right--for example the heads date coded C049/C059(march 4th & 5th, 1969), intake manifold date code C119(March 11,1969) . Any ideas anyone?
LATECH 02-20-2013 06:31 PM
Could it be a factory replacement maybe...just a guess.
LATECH 02-20-2013 06:36 PM
2 Attachment(s)
You are talking about the number that goes here Right?
painted jester 02-20-2013 06:36 PM
2 Attachment(s)
There is no number here (arrows)
http://www.hotrodders.com/forum/atta...1&d=1361410546
http://www.hotrodders.com/forum/atta...1&d=1361410589
Rosylab 02-20-2013 06:51 PM
Hi guys. Thanks for the quick reply. It's the VIN number that's missing. The production number (0599899) and the Type code(YS) IS stamped up above where it should be.
painted jester 02-20-2013 08:58 PM
Some GM plants stamped the bell housing not all vin. stamps were in a mandatory spot and the whole vin# was not always stamped! and The plant, date, and engine ID codes were stamped at the respective engine assembly plants while the partial VINs (when applicable) were stamped at the final assembly plant. Therefore the two stampings will have different fonts, character sizes, and in some cases will be stamped at different locations on the engine block! I do remember that early on Vin stamps were not manditory it was volintary from plant to plant I don't remember when it became manditory
Jester
Rosylab 02-20-2013 09:18 PM
I understood that all vehicles 1968 and after had to have the partial VIN number stamped on the front of the block where you noted in your thumbnail above.Perhaps not all block manufacturing plants got up to speed as fast as others. The car DATA PLATE indicates the car was assembled in Fremont Calif but who knows where the block was manufactured. Interestingly, the M-40 trans has the correct partial VIN stamped on it. I guess I'll just keep looking elsewhere on the block . If I find it I'll let you know .
Rosylab
WDCreech 02-20-2013 11:27 PM
I have seen a couple of blocks that had the partial vin partially or completely covered by the timing cover.
Bill
Rosylab 02-20-2013 11:58 PM
That's good to hear Bill although I'm in no mood to rip off my timing chain cover just to have a look. I will look closer at it though--maybe I will be able to see something peering out from under the cover that I may have missed before. Maybe when I pull the engine to change a leaky pan gasket (who came up with that design???) I'll dig a little deeper into this. I'll be able to examine the whole block then. The more I think of this the more I suspect that LATECH might have been on to something when he suggested that this may be a replacement factory engine. That would explain no VIN number. This whole drive train is pretty weird. I know the tranny is original and the rear axle may be as well. It is coded a WB which indicates a 2.56 ratio which was an "economy" option c/w 2-bbl carb on the 400cid with much lower compression.. This gave a 260hp rating I believe . Some owner before me may have ripped out that engine and replaced it with a factory replacement YS. The joys of buying a 43 year old car. In any case, I've since replaced the 2.56 gears and replaced them (they were shot anyway) with an Auburn limited slip. I'm going to bed now to dream of something else.
cobalt327 02-21-2013 11:23 AM
The '68-up Pontiac 400 VIN number is not in the same place as a Chev. It cannot be removed by decking.
Rosylab 02-21-2013 11:25 AM
I don't have any history on this car past the guy I bought it from. It was originally bought in Sacramento---that I know because I have a copy of the dealer order form. From there I was told it spent most of it's life in Arizona and eventually ended up in Seattle before the guy I bought it from brought it up to BC (Canada) which is where I am. Who knows how many owners there were or what work was done and by whom in between. I can believe it spent most of its life in Arizona as it's completely rust free and the interior showed all the signs of sun damage. The no rust is the main reason I got it. I suspect the engine has been out of the car at least once because you can see the RTV oozing from the pan gasket and the motor mounts look too new. Maybe it WAS originally an "economy" engine with the low 8.6 CR c/w 2bbl carb. That would explain the WB rear axle with the 2.56 gears. A previous owner may have decked the block to get the CR up. The number on the existing 4bbl indicates it came from a Ram III orIV which might make sense if it was a replacement for the original 2bbl. I'll probably never know for sure unless I tear the motor down and check the innards. In any case, the car runs well and it will only ever be a "driver" for me so it's only general interest that's driving my curiosity. Anyway, the research is fun.
Mr. P-Body 02-21-2013 11:32 AM
Cobalt is correct. unlike Chevy, it's not stamped on the deck.
It IS possible, the partial VIN is stanmped vertically along the side of the timing cover, as previously suggested. Usually, it' covered with "yuck", but when cleaned up, readable. There may also be a "SR" stamped alongside the cover. That's a "Service Replacement" (warranty block) and many were "restamped" by dealers early on. I recall putting the codes on a 455SD under instruction from Pontiac, when they replaced one under warranty.
Thank you for refering to the transmission correctly. Many simply call it "TH400", because it is essentially the same except the case. Pontiac called it "M-40".
There's something really cool here, many are missing. You have a '68 GTO!!! (lucky ******!).... The "YS" indicates a 350HP 400 /auto trans. Is the "His and Her's" shifter still there? Let us know when you want to get started on restoration or modernizing! A couple of these guys are real sharp on the Pontiac.
FWIW
Jim
cobalt327 02-21-2013 11:51 AM
What heads are on it? The YS engine would have come w/16 or 62. The 2bbl engine used 45 heads.
If the engine was originally a 2bbl, they sure did you a favor by replacing it w/a "correct" 4bbl engine for that year. But it makes ME wonder if the 4bbl YS code engine is original and it had the rear end swapped out. But either way, it'll make a nice ride.
Rosylab 02-21-2013 11:58 AM
It can't be a "68". The VIN number on the dash and trans indicate 1969 and it does NOT have the 1968 and older vent windows. Some of the obvious signs that this a 69 are that the front end nose has the correct 69 lights and the rear has the 1969 bumper with the taillights above not in the bumper per 1968. Everything about the body screams 1969.
WDCreech 02-21-2013 12:09 PM
YS was also used for '69 GTO engines. Jim may have mistyped that '68. If it were a factory or dealer replacement block, it would have been stamped SR instead of YH.
Bill
