1969 Mercedes 280SE - SBC350/T-10 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 09-04-2012, 04:15 PM
Last journal entry: Paint
A Saginaw 4 speed has the reverse shift lever on the side cover. A Muncie and T10 have the reverse lever on the tailshaft housing. Just looking at one of the older car 4 speeds you can tell it from a 3 speed. 4 speeds use 3 shift levers and a 3 speed only uses 2.
  #17 (permalink)
Old 09-04-2012, 04:52 PM
Originally Posted by ssimpala View Post
Looking good! I like the yellow.
Originally Posted by V8&4spd View Post
I thought you might have had a 1 piece seal engine since you mentioned the 1 piece seal oil pan. I have both the 10.5 and 11 inch flywheels for a 2 piece seal engine, I also have a billet flywheel. That's a Saginaw 4 speed transmission.
Well ****.... I don't know how I didn't notice that before... So I have a Saginaw then
Mine is a 2-piece rear main (1981 Camaro Block) and that bell housing is for a 153-tooth flywheel.
  #18 (permalink)
Old 11-01-2012, 12:01 AM
So I am still accumulating parts at the moment, starting a new job in a few days so I should be making some more progress here shortly.
Figure I would ask if anybody has run into this problem before... I am trying to find a 2 or 3 Pedal assembly that is floor mounted, cheapest I can find are these Tiltons that are $200 and $400 before another $160-$240 in master cylinders.
Anybody know of anything cheaper or possible a different way to approach this?
I would love a sponsor
http://www.tiltonracing.com/sites/de...Assemblies.pdf
Tilton Floor Mount Pedal Assemblies 72-603 - SummitRacing.com
Tilton Floor Mount Pedal Assemblies 72-604 - SummitRacing.com
  #19 (permalink)
Old 06-23-2013, 03:35 AM
Finally got around to starting on the car itself now, considering I have owned it for 2 years now....
Got the engine running but the carb still needs some work, once that is in order I can break in the cam.
Interior is all stripped out now and i'm in the middle of taking out the sound deadening, found a bit of rust and made a few holes myself but nothing that cant be fixed in a few seconds.
Made some seat brackets that I will put in place once I have everything cleaned and painted (the picture is kind of misleading, when installed the longer side sits level, that's how steep the angle of the floor pan is)
  #20 (permalink)
Old 06-28-2013, 03:14 AM
Last journal entry: more photos
im building a ratrod fom very simular car
im building a ratrod fom very simular car mine is a 1968 220 mercades benz had lot more rust but very im useing it but have another 1961 or as a parts doner along with another 1961 i think i got thats fuel injucted 6 cyl.lol fun to fo a franky build lol
  #21 (permalink)
Old 06-29-2013, 01:33 AM
Got some more stuff done.
  #22 (permalink)
Old 06-30-2013, 02:44 AM
If that was my car the top seat belt mounts would be on the parcel shelf in front of the rear window.
Much stronger and less likely to break your back in a big acco.
  #23 (permalink)
Old 07-02-2013, 02:18 AM
I am just using those mounts until the cage goes in. And the rear deck is made from 14 gauge steel, that's a far cry from the current mount that goes into a frame cross brace that is almost 1/4" thick.
  #24 (permalink)
Old 08-20-2013, 01:18 PM
Prep for interior paint...
Engine all ready to go...
Starting the Saginaw
Current Exterior
  #25 (permalink)
Old 08-20-2013, 02:25 PM
Banned
looks good. any video of her running.
  #26 (permalink)
Old 08-20-2013, 02:53 PM
Sorry, forgot to add that.
  #27 (permalink)
Old 08-20-2013, 04:54 PM
Banned
does not play , say this video is private.
  #28 (permalink)
Old 08-20-2013, 05:55 PM
I've got to ask, do you rally the car of a night?
Those big Hella's must be there for a reason.
The Following User Says Thank You to zuffen For This Useful Post:
mr_firewall (08-27-2013)
  #29 (permalink)
Old 08-23-2013, 06:51 PM
JGK95's Avatar
Last journal entry: Test Entry
This car is an exceptional build! However, you got to get rid of those rubber hood straps at the front. Ya know, you could totally pull off the sleeper look! I've been following this build for quite a while. Keep up the great work!
The Following User Says Thank You to JGK95 For This Useful Post:
  #30 (permalink)
Old 09-09-2013, 03:52 PM
Sorry, just made it public.
When she is ready and running I will be doing some night time rally and dirt track racing out in the desert. Not a lot though, I mostly have them on right now for mock up and to make sure I like them there.
I put the straps there because I liked them and they reminded me of Red Pig. At the moment I could put the bumpers back on and make it a sleeper but once the new rear axle and front end goes in its not gonna look stock at all Hope you like it so far, thanks.
New cam in SBC350 - WHAT TIMING ? ... custom_rider Engine 1 03-14-2012 04:37 AM
sbc350 donald1976 Hotrodding Basics 1 03-04-2012 11:19 AM
Good sbc350 buy? BmoreChevy55 Engine 4 08-18-2011 07:49 AM
Building a mpg sbc350 bigals77 Engine 8 05-01-2011 02:00 PM
Sbc350 SBC355 Engine 5 04-01-2008 02:22 PM
