1969 muncie 4 speed transmission
I have an 1969 muncie 4speed trans, when you pull the nose cone is there suppose to be a oil seal because it leaks oil out the fornt of it.
I have an 1969 muncie 4speed trans, when you pull the nose cone is there suppose to be a oil seal because it leaks oil out the front of it. how can i date code it. shifter plate num. is 3953648 main body num. is 3925661 and the nose cone num is 3915020. please help, thanks jerry
If the trans takes a seal, you should see evidence of the seal riding on the input shaft. Some inputs dont have a seal worthy surface. Some brearing retainers dont have a bore to install a seal, yet some do but the trans did not come with one. Maybe Autogear will chime in with the complete info.
Hi
Yes there is a gasket that goes behind the bearing retainer (nose cone) a whole transmission gasket & seal set cost about $25. Rich PS http://www.ecklerscorvette.com/corve...roduct_Related |
Some transmissions had seals, but I do not remember any Muncie 4-speeds having one, but you should be able to see the old one and just replace it if it has one.
Also, all the 4-speed trans that I remember had a oil slinger on the input shaft. Might check for that being missing. Over filing was the major reason the Muncie 4-speeds leaked out the front. |
Corvette Transmission Gasket & Seal Kit, Muncie 4-Speed, 1963-1974
Click on above image to view full picture(s) 1963-74 (C2, C3) Muncie 4-Speed Transmission Gasket & Seal Kit Corvette Transmission Gasket & Seal Kit, Muncie 4-Speed, 1963-1974 Manufactured From Factory Grade Gasket Material USA Made Seals .................................................. ...1964 -74 front retainer gasket Kit includes side cover gasket, 1963 & 1964 -74 front retainer gasket, tail-housing gasket, mid-plate gasket, 1963 - 70 small and 1970 - 74 large tail-shaft housing seal, three shifter shaft seals and a speedometer fitting o-ring. Part #: 42628 Price: $21.99 Set Low Price Guarantee Qty: Availability: In Stock Hi Mark everything going well? Last edited by richard stewart 3rd; 06-23-2011 at 06:11 PM. |
OEM muncies used a 'gland nut', 'windback threads' or 'front bearing nut' (GM P/N 591150) This was a GM design since the 1930s. The idea is the oil hits the backwards threads and the oil is slung back up the shaft, thereby preventing it leaking. I use 'preventing' loosely as they always dripped a little oil (there is a weep hole to allow oil to escape without contaminating the clutch surface).
In response to the seal type; There are seal-type inputs (sometimes called a maindrive) for the Muncie. And there are 2 ways to go about them. First way (very short explanation for illustration) : mock up the standard input with the nut and note how many threads are left after you snug the nut down. Disassemble. Turn the 'extra' threads off and use a special oilseal on your newly created surface (Auto Gear 0-044-011 / MCL 2400220). You will need to modify the nose cone (input bearing retainer) as well (easier to buy the proper retainer for less than $30) Second way: Buy an Auto Gear 'oil seal maindrive' and the specific Auto Gear oilseal-type input bearing retainer. We're the only ones that make them, and they're marked either Antonio Masiero (an AM mark) or Euroricambi (which is a pyramid shaped E) Retainers have Auto Gear cast into them with pn 18-027-002 (standard size) or 18-027-004 (5.125" dia truck bellhsg seal-type retainer) You could have accidentally covered the weep hole as well. If anyone wants to attempt the thread to seal conversion, contact me first and I can help you with some specifics; this is definitely measure twice, cut once territory. My suggestion is to get a new input and nosecone though. EDIT: In response to Richards post, 63 only Muncies have some subtle variations and usually can be problematic when you use 64-65 parts in them. There is a 63 specific gasket set out there. |
| Muncie 4 speed transmission | hotchevellechick72 | Transmission - Rearend | 2 | 02-27-2010 09:25 PM |
| 4 speed Muncie Help ?? | super_silent | Transmission - Rearend | 14 | 11-22-2007 07:38 AM |
| Muncie 4 Speed Transmission | junkyjerry | Transmission - Rearend | 2 | 10-29-2006 07:40 AM |
| Muncie 4 speed transmission | dzguy | Introduce Yourself | 3 | 10-01-2004 01:59 PM |
