1969 mUSTANG 8" FOR A 65? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2007, 08:59 PM
i AM TRYING TO FIND A NEW REAR END SINCE MY 7 1/4 IS A WEAK UNIT ACCORDING TO YOUR MEMBERSI found a 69-70 8" but unsure about the interchangability of the tube length. probably longer eh?
Thanks
Old 11-20-2007, 09:13 PM
Putt's Avatar
I have a chart for the 9" in these cars, I would think the 8" is the same width(disclaimer ) It lists the '65 as 52 1/4" total width flange to flange, and the '69 as 54 1/4" total. So if info is correct the '69 is 2 inches wider, the spring pads are the same distance apart.
Old 11-21-2007, 07:28 PM
Wiki Edits: 31
yes.. won't work w/ factory rims. '69 and 70 stangs are a wider body car, so things like that arn't quite right.. you could get rims to correct the offset tho.. 2" is all you would need
65 Mustang Convertable Blair 73 Introduce Yourself 4 11-18-2007 08:42 PM
65 mustang customizations? MrPhotographer06 Body - Exterior 8 01-10-2007 05:06 AM
parts swapout 65 mustang freak General Rodding Tech 2 02-28-2006 05:33 PM
65 Mustang hood ornament cybercat133 Body - Exterior 3 01-29-2006 09:50 AM
65 mustang rearend tonylsg Transmission - Rearend 5 04-12-2003 10:40 AM
